Speakers need current to operate right ?
I mean, if you have an output stage with very low current, but very high voltage, both under and over the requirements respectively, will the speaker work ?
The magnetic coil in the speaker actually needs current rather than voltage in order to create the flux required to move it. So if your output stage has very small currents, BUT very high voltage, that's a failure right ?
So therefore, what's the purpose of power amplifiers in speaker circuits? If all you need is a high current, why is power amplified anyways?
