power hold circuit,, will it work?
wirror
Joined Apr 11, 2022
Thank you for reply~
My intended sequence of actions is as follows:
1. Push the button (SW440) for a while
2. The Gate of P-CH FET goes Low, SYS_PWR_EN goes High
3. PS_HOLD goes High by MCU
4. SYS_PWR_EN remains High when the switch(sw440) is released.
after that,
I want the MCU to be able to detect when a switch(sw440) is pressed, through the PWR_KEY_DET
Papabravo
Joined Feb 24, 2006
22,113
after that,
What happens if the switch(sw440) bounces for 20-50 milliseconds? Is that going to cause a problem?
38,844
What is the battery voltage VBATT?
D400 has a clamp voltage of 3.3V, which will conduct if the VBATT voltage is >3.3V and possibly turn on the MOSFET.
boostbuck
Joined Oct 5, 2017
1,064
PWR_KEY_DET is pulled low via D652 when the key is operated (so it is active LOW), but there is no pullup to return it HIGH (inactive) when the key is released, unless the MCU pin has a pullup internally.
