E-book Correction Possible error in vol 1 chap 4 part 1 Scientific notation
Auke L. Klazema
Joined Nov 21, 2014
7
Wendy
Joined Mar 24, 2008
23,812
Take note of those two numbers and of the relative sparsity of non-zero digits in them. For the mass of the proton, all we have is a "167" preceded by 23 zeros before the decimal point. For the number of electrons per second in 1 amp, we have "625" followed by 16 zeros. We call the span of non-zero digits (from first to last), plus any zero digits not merely used for placeholding, the "significant digits" of any number.
Note the section describes numbers of electrons vs. mass of a proton.
Not verified.
ScottWang
Joined Aug 23, 2012
7,505
Hi All,
First post. I think there might be an error in chapter 4 part one of volume one.
http://www.allaboutcircuits.com/vol_1/chpt_4/1.html
Take note of those two numbers and of the relative sparsity of non-zero digits in them. For the mass of the proton, all we have is a "167" preceded by 23 zeros before the decimal point.​
It talks about 23 zeros before the decimal point. Shouldn't that be after the decimal point?
Greetings,
ALK
In the beginning I was thought as you did, but I saw many times tried to figure out why it describe that way, I think the "before" here was represent the number is less than 1, if using "after" it means that the number is bigger than 1.
I think these are the position and direction problem, if the decimal point "." is a standard position, the right side is the number less than 1, and the left side is the number bigger than 1, so when we comparing the "." and 167 or 23 zeros, the "." is on "after" position, the 167 or 23 zeros are on the "before" position.
00000 00000 00000 00000 000
Proton mass = 0.00000000000000000000000167 grams
Wendy
Joined Mar 24, 2008
23,812
Ah, so it should be rephrased,
Take note of those two numbers and of the relative sparsity of non-zero digits in them. For the mass of the proton, all we have is a "167" preceded by 23 zeros after the decimal point. For the number of electrons per second in 1 amp, we have "625" followed by 16 zeros. We call the span of non-zero digits (from first to last), plus any zero digits not merely used for placeholding, the "significant digits" of any number.
OK, verified.
