Portable power supply
Dr.killjoy
Joined Apr 28, 2013
1,196
I was looking into playing with a portable power supply.. I will be using it for basic bread boarding and I was wondering if you guys would use a smps or linear supply .. It just gets to be a pain to keep dragging my large power supply out when I am barely using way less than 1amp and under 12v dc.. Oh I was looking at using the
lm2596 already built regulator from ebay if I decide to go with it .
dl324
Joined Mar 30, 2015
18,473
Buy a wall wart and make/buy a bread board supply board. Fits on one side of the breadboard. Don't recall if the voltages were adjustable, but it wouldn't be difficult to roll your own. I use linear supplies; less complicated, cause fewer issues, and I don't worry about efficiency when I'm testing.
#12
I decided that I would use the 78Lxx and 79Lxx linear regulators for a 1/10th amp limit. That covers more than 90% of the little test jigs I explore. Most breadboard circuits are just, "proof of concept" tests. A couple of what-ifs and a few adjustments will demonstrate the uncertain points. I can still haul out the 8 pound Variac, but I rarely need it. Besides, pouring an amp through a little plug-in board is risking melty things.
dl324
Joined Mar 30, 2015
18,473
We use a lot of 5v cellphone chargers, the students get them from the Goodwill store for a dollar each.
The Goodwill stores in my area charge $3 for most adapters. Kind of pricey for a cellphone charger, but okay for 18VDC@1A. Best to get them when they're 50% off if you can.
Dr.killjoy
Joined Apr 28, 2013
1,196
Here is what I ordered from ebay ..
http://www.ebay.com/itm/New-110V-DI...379?pt=LH_DefaultDomain_0&hash=item1c511bb42b
US Plug 110V DIY LM317 Adjustable Voltage Power Supply Board Kit With Case
Features:
One way adjustable signal generator output. Convenient to provide the pulse signal
With a logical pen function. For convenient the logic level of test circuit
With one way buzzer. You can test the wires on and off (connect the wires to the power positive and signal input, the wire on - the buzzer sound). You can also test the low-frequency signal (input the signal from the signal input, if there is a signal, the buzzer sound)
Specifications:
Power: 2W
Voltage: 110V (update in 2015-03-11)
Plug: US plug
Output voltage: 1.25V - 12V regulated output continuously adjustable.
PCB board size: 7.3 x 6.8cm (W / L)
Shell Size: 11 X 6.9 X 41.5cm (L / W / H)
Weight: about 295g
Package included:
1 x DIY LM317 Kit
#12
LOL Stop making fun of me ...:)
It IS cute! See-through case, lots of different colored LEDs, captive nut holders... :)
If I wanted to make fun of you I would say the knob looks like an after-thought and it has a power cord, which seems incompatible with the word, "portable" (in your first post).
I was just being my usual, honest, self. I think it's squee cute, like the avatar for Sinus23. :p
#12
Probably the usual way, P=IE
2W = I 25V
25V x 80 ma = 2W
The auction is still open and there is a button to, "Ask a Question" if you want to hear from the seller.
ian field
Joined Oct 27, 2012
6,536
Wall-warts is pretty much how I do it much of the time.
Appliances come and go, and often leave a wall-wart to go in the junk box, so its usually easy to find one that fits the job quite well.
If you're developing a project for publication in an electronics magazine, a wall-wart as the power source avoids the need for DIY power supplies and gets out of oh - so many problems.
99% of the time, local regulation issues can be taken care of with 78xx regulators. The old iron-cored transformer variety wall-warts are becoming increasingly rare - on the SMPSU type, the regulation ranges from not too bad to pretty good.
upand_at_them
Joined May 15, 2010
939
The LM317 can do up to 1.5A. They should be quoting 12W or 18W. Their rating is probably based on that wimpy transformer.
I don't like that they decided on an acrylic enclosure. May be easy for them to laser cut, but not a wise choice for a power supply. And I wonder if they isolated the regulator tab from the heatsink; the LM317T tab is connected to it's output.
#12
The 317 comes in several flavors from 1/10 amp to 1.5 amp and SOT to TO-3. The limit on this one might be having more than 12 volts for Vcc and trying to deliver 1.25 volts at minimum adjustment value. Maybe 12.75V x 0.08A = 1.02 watt on the regulator chip. No, that doesn't seem right. Probably the transformer, as you said.
Dr.killjoy
Joined Apr 28, 2013
1,196
The kit is $17.99 with free shipping.. My plan was to try it out and see what happens and if all else fails then make my own power board and use the clear case.. I figured you can't go wrong for the price..
#12
Yep. I've done that. Bought a multifunction screwdriver/nut driver for 50 cents, just to get the telescoping magnet mechanism from it.
Dr.killjoy
Joined Apr 28, 2013
1,196
Lol I wasn't sure but figured you where having fun with it ..
How did they calculate the power at only 2W?
Remember it's from china and at least it's in English and the specs are off but will have to wait til it's here..
I have plenty of walwarts laying around but I want something simply for protoyping
and proof of concept
Whats wrong with using acrylic for a case ???
I got one of these a few years ago: http://www.amazon.com/Elenco-Triple-Output-Power-Supply/dp/B0002DT0GU
Much more than $17, but: It's a kit. Has a metal enclosure. Proper banana jack outputs. Bigger heatsink, with properly isolated regulators. Larger current output. You can change the AC outputs to something useful. It doesn't have a display, but I added one for a few dollars (PIC, LCD, and op-amp).
I like it alot and that would be a pretty cool project but I already a Mastech 30v 3amp dc power supply .. My problem is that my work space is my kitchen table and it gets to be a pain to drag my power supply out for a simply circuit or for prototyping ...
#12
Acrylic might not be as fireproof as steel. It also doesn't dissipate heat as well as steel. You must decide if it is proper for your safety.
