Polarity switching components
Anton179
Joined Aug 10, 2019
11
I am a mechanic and I’m designing my own latching relay circuit to turn power to my fuel pump on/off with a pulse provided by my remote/immobiliser.
I’m not an electrical engineer and I need some help designing this circuit. I have an Omron 12VDC latching relay but did not realise that you have to change the polarity to flop the relay back the other way.
Is there any electronic component that can automatically change the polarity on the 2nd pulse?
(Attached is a schematic of the 1 pole relay)
jpanhalt
Joined Jan 18, 2008
11,087
Welcome to AAC.
Do you want the switching to be automatic, e.g., after a set delay, or can you use a manual switch? The latter is easily done with a DPDT switch. Power to center pair, latch and reset to the outer pairs of contacts.
Anton179
Joined Aug 10, 2019
11
I should have also said that my remote pulses a 200mA ground only.
Also this is not a vehicle modification as the vehicle is from the year 1964! It is rather a security upgrade for my aftermarket keyless entry system.
jpanhalt
Joined Jan 18, 2008
11,087
With a pulse like that, you might considers a relay similarly wired. Do you also want a "no power" (e.g., center off) position?
Anton179
Joined Aug 10, 2019
11
Welcome to AAC.
I would like it to be automatic so I don’t have to open the boot and press a button. Just using my remote.
30,658
If you now have two momentary pulses for on & off, you could use two small bridge rectifiers to 'steer' the opposite polarity to the relay.
Anton179
Joined Aug 10, 2019
11
Is it too late to get a different latching relay? Here is one I have used successfully. It is a true toggle type - the same polarity coil pulses latch it on - off - on - off ...
This is what I need but it’s quite large. I’m only switching 5amps max
iimagine
Joined Dec 20, 2010
512
Talking about a latch that controls a latch
Heres my way of doing it:
Assuming your pulse is 12V
This circuit remembers the state and switch it automatically.
How it works:
It centered around a D-Flip Flop, the input pulse triggers the flip flop, the flip flop then trigger a 'one shot' pulse to turn on/off the relay oppose to the previous set state
Edit: Note: LEDs resistors need to be calculated. I forgot to change them
bwilliams60
Joined Nov 18, 2012
1,450
I would build in a safety factor in case the button gets pushed and the fuel pump is turned on. If left your battery goes dead. Something along the lines that it has to see an ignition pulse or charging system pulse or it shuts the pump off after x seconds.
Anton179
Joined Aug 10, 2019
11
Fuel pump won’t turn on unless there is oil pressure. I have an oil pressure switch.
Anton179
Joined Aug 10, 2019
11
Surely there is some type o
How it works:
can you describe to me how this circuit functions in other words?
iimagine
Joined Dec 20, 2010
512
Its a simple 2 transistors latch on/off. When a button is pressed, current flows into C1, charging it up, when current flows, voltage drop, thus Q1 turns off. At this point Q1 no longer draws current from the base of Q2 and since no current draw, voltage rise therefore, Q2 turns on. Q2 draws current from the base of Q1 thus keeping it off. When the button is pressed again, C1 discharged to the base of Q1, thus turns it on, as it turns on it pulls the base of Q2 low, Q2 turns off. Q1 keeps C1 discharged. C1 is pretty much a memory cell.
The circuit in post #12 replaces the switch with with an N-Mos so that we can apply a pulse to change the state of this circuit. Since Q1 and Q2 can only be in an on or off state, we need some way to generates a pulse when they are on so that we can use that pulse to trigger the relay, thats what the other 2 mosfets are for.
Anton179
Joined Aug 10, 2019
11
This is brilliant thank you! Now all I need is to make it! I really don’t like my chances, I think I need to find somebody to help me or to do it for me…
BillB3857
Joined Feb 28, 2009
2,573
If you can live with two SPDT momentary pushbutton switches (one ON, one OFF), this would be a simple implementation. Each switch would supply a momentary pulse with one switch setting the relay and the other switch resetting it. It is basically a pushbutton H-Bridge.
