I just read the original post again and realized you want REMOTE operation. Wouldn't the simplest fix be to tie the fuel pump supply into the ignition circuit of the car?If you can live with two SPDT momentary pushbutton switches (one ON, one OFF), this would be a simple implementation. Each switch would supply a momentary pulse with one switch setting the relay and the other switch resetting it. It is basically a pushbutton H-Bridge.
