Hey yaakov, thanks for your response.Welcome to AAC.
Would what work? PoE is a source of power, but you haven’t said what you were going to do with it. Similarly, changes to what?
Do you have a circuit in mind? Schematic? Even a simple drawing? A module? The PIR sensor?
Are you going to use the Ethernet? Are you planning on using some Ethernet connected device at the PIR sensor end to communicate the state of the sensor?...so the PoE switch acts as a source of power for the circuit.
What is the PIR sensor? Do you have a PoE circuit or module in mind? Will the PoE sensor communicate via Ethernet?Hey yaakov, thanks for your response.
My idea is to power my PIR DC Circuit with a cat.6 cable, I know it's a bizzare idea but i want it to make it work( by "it" I mean my goal here is to replace a 12V DC input and power the circuit from a cat.6 cable coming from a PoE switch) so the PoE switch acts as a source of power for the circuit.
by Don Wilcher
by Robert Keim
