POE - signature detection
puzzle
Joined Oct 30, 2016
53
In the POE process (http://www.veracityglobal.com/resources/articles-and-white-papers/poe-explained-part-2.aspx) there is an initial step called - Signature detection. in this step the PSE (power sourcing equipment, POE network switch for example) is inducing a small voltage level on the PD's internal 25K ohm resistor and then it determines whether the connected PD (power device, IP camera for example) is a POE compliant or not.
I'm wondering how does this sensing is done by a MCU ? Is it a current sensing ? How can it be done ?
thanks
wayneh
Joined Sep 9, 2010
18,149
Well, I think there are two choices: Apply a voltage and measure current, or vice versa. Then use ohms law to validate whether the resistor is the right value.
The text hints at applying a voltage well under 48V but it's not definitive in my opinion, that it's a fixed voltage. That'd be my guess though. I'd test it or find a more detailed reference.
puzzle
Joined Oct 30, 2016
53
I'v read that in order to measure current, and let's assume the 25Kohm resistor is the load, you need to connect in series a shunt resistor, to amplify the voltage sampled on the shunt resistor and get this value into an ADC. Is that can be a possibility ?
It's generally done by a dedicated chip. LT has been pretty active in the development of POE. Here http://www.linear.com/product/LT4275 is probably one of their latest designs for the PD (or Powered Device). There is a two-step process depending on the power delivered.
The initial signature uses two voltages from 2.8 to 10 V and does a ΔV/ΔI to determine R.
POE is still messy in my opinion. Some early installs were done with only 4 conductor cables. There is some oddness of what a crossover gigabit cable really is because technically Gigabit doesn;t care how the cables are plugged in. I think, I'm right but a Gigabit xover cable technically does not cross the spare pairs. It can get away with it though.
So, if you have a 100 base T with only 4 wires, you have to be careful and you'll likely need a Gigabit compatable PD and PSE. Things are more rosey when all 8 conductors were run.
Then there's POE without any standard which is just power down the spare pairs and your just asking for trouble. Polarity doesn;t matter because the pairs are full wave rectified and combined.
Not sure if all of the pairs are POE detected. meaning, I don't know if you can put the highest classification over just 2 pairs.
The voltage did increase for POE from the earlier standards.
