Pocket pH meter storage
xchcui
Joined May 12, 2014
309
Hi.
At the attached photo you may see a type of pocket pH meter.
On the following link you can see the pH meter dismantled:
https://www.allaboutcircuits.com/news/teardown-tuesday-digital-ph-meter/?cb=1574800939
The manual says:when you finish the measurment,you need to clean/stir the electrode bulb with distilled water,
DRY the electrode bulb and replace the protective cap before store the ph meter.
As far as i know,ph bulb electrode should be stored wet or be in a storage solution.
Could it be that this type of ph meter has a different technology/operation?
Thanks.
jpanhalt
Joined Jan 18, 2008
11,087
That looks like a conventional pH electrode bulb to me. Given its location, I don't see how one could dry it easily, but given the way it is packaged, one might anticipate problems related to the high humidity from storing it wet.
Too bad the "tear down" didn't mention anything about function. Seems like more than a little oversight to me.
SamR
Joined Mar 19, 2019
5,535
We always cleaned them and stored them suspended in a beaker of distilled water kept in a closed vent hood to prevent contamination of the water. That would not be practical for that model.
Edit: After looking at the Cole-Palmer link it jogged my memory. We suspended them in pH 7 buffer for storage, not distilled water.
xchcui
Joined May 12, 2014
309
The manual says to suck gently the water from the electrode bulb with filter paper.What problems may occur if storing it wet?
Is this ph meter,also,leak some kind of electrolyte to the
tested solution in its operation(as the regular ph meter)?
Also,in the attached link the reference electrode that can be seen in the dismantle ph meter is just a wire without any casing,is it made like that or maybe the casing of the reference electrode broke when he dismantle the ph meter?
atferrari
Joined Jan 6, 2004
5,027
First time I hear those electrodes are kept wet and not dry. Surprising to me.
Look around paying attention and you learn things every day! :D
xchcui
Joined May 12, 2014
309
Jpanhalt,thanks for your reply,but i think that all your
links refer to non pocket ph meter.
Lets put the dry issue aside and focus on my other question:
What is the small round part that i marked with a red arrow(in my attached photo)?it looks like the end of the reference electrode,but i am not sure.
SamR
Joined Mar 19, 2019
5,535
pH measurement is an arcane black art. I did it several times a shift as an analytical chemist but as a process control engineer, we had a real headache of a problem doing an onstream analysis of some very nasty acidic wastewater that had to be neutralized before being sent to the cities wastewater plant. They got a bit irate when we killed the "bugs" in their wastewater digester with our acidic waste. We went through probes like popcorn at the theater. Ended up pulling and calibrating/replacing probes every 4 hours.
xchcui
Joined May 12, 2014
309
...Since technical information on that meter is limited to the link you provided, perhaps its author (@NickDavis) can address those questions.
I can't see any way to make with him a contact about this question.Its article was written 2 years ago.
Anyway,jpanhalt and Samr,thanks for your replies.
I just a little bit disappointed that you couldn't answer at least to one of
my question,but thanks again for trying:)
jpanhalt
Joined Jan 18, 2008
11,087
@xchcui
It's not that I can't answer that question with respect to typical analytical pH meters, it is that your meter is apparently special and may not be subject to the usual approaches.
