Plz help. What diode for 12 volt 10 amp battery backup circuit
bigjoncoop
Joined Feb 1, 2019
204
I need a diode for dual DC power input circuit basically battery backup. Every barrier, blocking, rectifier diode I can find on Amazon rated for 10 amps or greater all say for solar panels. Can I use these diodes on my circuit? The circular will pull no more than 10 amps at 12 volts.
bigjoncoop
Joined Feb 1, 2019
204
Okay. I figured as much. Just second-guess myself because literally every rectifier, blocking, schottky diode I could find listed on Amazon rated over 10 amps all said for solar panels in the title. I just received them in the mail yesterday. I'll let you know how it works out
Thanks again
Picbuster
Joined Dec 2, 2013
1,062
The best way is to use mosfets to create an ideal diode.
google for ideal diodes or fet as diode.
advantage V_forward <12mV @ 50 Amps ( this is an example look at datasheets).
Picbuster
