I have recently the circuit below and powered it with a Lithium battery rated at 9.6VDC. The actual voltage was measuring at 10.4V, but the negative output was measuring at 9.35V. If I were to run a dual supply IC I would want the +/-
voltages to be as close as possible... How might I achieve this in this circuit?
