Plotting Color Scope Shots to Mono Printer
SamR
Joined Mar 19, 2019
5,538
Kind of an odd request for an Electronics forum but I hope someone has some experience here. The problem is when trying to print this scope shot to a monochrome printer it is really hard to read. Maybe I can change some colors on the scope? But does anyone have any advice here?
SamR
Joined Mar 19, 2019
5,538
I think I may have found it. There is an invert option on the display menu for the scope. Looks like hell on the scope but prints much better. Still not perfect the color for channel 2 is almost invisible even on the print. Still room for improvement. Don't see any way to change colors on the scope.
@tautech any advice?
SamR
Joined Mar 19, 2019
5,538
OK, can't change pen colors but there was another style selection on the display menu that kinda works. At least better and apparently about all I can do at the scope. At least I can read the print better.
EDIT: Gah... That looks so bad... At least it looks better printed mono.
Reloadron
Joined Jan 15, 2015
7,954
Just about any photo editor program should let you convert to grayscale (B&W). I used an old version of Paint Shop Pro 7.0 by JASC software. GIMP as mentioned is good free software as is Infranview. Just about any photo editing software which will allow changing a color image to greyscale.
Ron
SamR
Joined Mar 19, 2019
5,538
I installed Gimp but now I'll have to learn to use it or at least look at it. Not a big fan of paint programs but I do use them for grabbing schematics to print/edit and my scope shots. Thx guys!
SamR
Joined Mar 19, 2019
5,538
Yeah, that is the trick it seems although it looks terrible on the scope screen it isn't too bad printed. I could find no way to do it within the paint program. Kind of a hassle to change the scope settings back and forth. I did leave the screen color scheme set to a "classic" blue mode that I can live with so I only need to hit the invert button before I do a screen save to get a printable screengrab.
Alec_t
Joined Sep 17, 2013
15,157
Whether gray-scale or black and white, it's better to have dark traces on a light background if you want to economise on printer ink/toner.
jpanhalt
Joined Jan 18, 2008
11,087
The setting changes I mentioned are made at the print level, not the scope (raw png scope image on left):
I save as png (default Rigol). Then open in Photoshop (CS3, now free*), not some disabled tool like Win7 Windows PhotoGallery. At that point, you have several options. You can convert to B&W (as above) or leave be. The simplest is to just go to the print dialog and click negative:
My printer is a Brother HL2270DW. That usually prints just fine (maybe its printer dependent) without having to go through the B&W. I do the same with LT Spice images.
*I bought my PS version CS3 in 2007. It is way outdated. A few years ago, I noticed it was available from Adobe for free. I don't know if that still exists or whether later versions are now available free.
ci139
Joined Jul 11, 2016
2,034
any advice
you likely want to save the ink/toner so everything unimportant shouldn't print
basically you need a b/w framework and the traces to be distinguishable either by luminosity or pattern
doing it manually
or
you can select the "background" transparency so if the background matches some color then pasting a cut image back onto another color replaces the background color of the entire paste block
or you can save your image as 24-bit bitmap and alter the content programmatically say with the MSO VBA or whatever you got ? a QBasic perhaps
SamR
Joined Mar 19, 2019
5,538
I tried the color change with "paint fill" and the results were terrible. Transparency didn't really do anything. So far the easiest with good results is using the "classic" color scheme on the scope and the scope's display invert before saving the screenshot. After that simply open the file and print with good results. The blue frame with the "classic" scheme is a bit bright and not my prefered scheme but tolerable and one less button to have to push before saving. Seems the best solution, for me, was on the scope and not by manipulating the image on the computer other than framing for printing. I am also using a Brother Laser Printer/copier/scanner/fax. Gave up on color/photo printers long ago now.
ci139
Joined Jul 11, 2016
2,034
if you have the Photo-Shop you could brake the image to R,G,B vectors reweigh them ?? blue darkest . . . green lightest , re-merge , monochromize , adjust the gamma and the lightness (the last two must be tested out for best printout contrast and brightness)
