Please help me code an if statement in 'C' for Arduino
flat5
Joined Nov 13, 2008
403
Idea is to check a string for a character and not concat it if it is already in the string.
My if statement does not work and I do not have a clue why.
Code:
void random_code() {
  // send a random character's Morse equivlent
  char* code_char[] =
  { "a", "b", "c", "d", "e", "f", "g", "h", "i", "j", "k", "l", "m", "n", "o", "p", "q", "r", "s", "t", "u", "v", "w", "x", "y", "z",
    "0", "1", "2", "3", "4", "5", "6", "7", "8", "9",
  char* codes[] =
    "-.", "---", ".--.", "--.-", ".-.", "...", "-", "..-", "...-", ".--", "-..-", "-.--", "--..", // 26 letters
    "-----", ".----", "..---", "...--", "....-", ".....", "-....", "--...", "---..", "----.",     // 10 numbers
    "--..--", ".-.-.-", "..--..", "..--.", "---...", ".-..-.", ".----.", "-...-"                  //  8 punctuation
  String send_char; String answers; char* send_codes[row - 1];//array starts at 0. User inputs how many characters in a run (row on screen)
  unsigned long seed = seedOut(31); randomSeed(seed);
  for (unsigned int t = 0; t < row ; t++) // each run will be 'row' characters (+ 'row' spaces)
    unsigned int randNumber = random(43); // 0 - 43, all characters.
    String chkchr = code_char[randNumber]; // the ascii character random has picked
 // PROBLEM IS HERE ---------------------------------------------------------------------------------------------------------
    if (chkchr == (answers.substring(0))) // see if the randNumber character is in string 'answers'. I will fix this later if a row is > 44
      t = t - 1;
    else
      answers.concat(code_char[randNumber]); answers.concat(" ");
      send_codes[t] = (codes[randNumber]); // array of code character strings to be sent
   Serial.println(answers); Serial.println();
33,140
Is this C or C++?
Check your random(N) function. Usually these functions return an integer n such that 0 <= n < N.
What does your substring(K) method do when K=0?
flat5
Joined Nov 13, 2008
403
I'm sorry, WBahn. I do not know for sure what you mean by substring(k).
I guess you did not care to type 'answers.substring(0)'.
If the random() returns 0 then that would point to the first character in the char* array.
I'm only asking for help with the if statement. I have done many checks with printing the strings at every point in the code. The characters are correctly returned - not the pointers.
Anyway, I had tried to use if (answers.indexOf(chkchr) != -1) before but now it works!
I will test some more but I think the problem is solved.
It would be nice to know why substring(0) did not work but indexOf(string) does.
Just for fun I set the row to 45 and the run got caught in the loop :) as it should.
Now to allow two of a character if the row is between 45-89.
djsfantasi
Joined Apr 11, 2010
9,237
In Arduino C, the substring method when used with only one parameter, returns the sub string from the parameter to the end of the "parent" string". Hence when used with the string "answers", "answers.substring(0)" is the entire string, "answers". You are checking against a single character variable, chkchr, so unless "answers" is a single character, your test for equality will always be false. I don't think that is what you want. Check out this reference
@WBahn and TS - Arduino's "random" function, random(M), returns a number from 0 inclusive to M exclusive.
33,140
The reason that I ask if you are using C or C++ is that the dot operator is a structure member dereference in C whereas it is an instance method call in C++. You appear to be using it to call instance methods.
Having said that, the embedded world has numerous non-conforming C compilers that go off into their own little world with specialized syntax extensions.
The problem I am trying to point out with random isn't that it will return 0, but that it will, most likely, NOT return 43. It will return one of 43 values, namely 0 through 42. Unless the random() function is very non-standard. Have you ever seen the last character in your strings come up, namely the '='?
In most string libraries indexOf(k) will return -1 if the character k is not in the string, otherwise it will return the index of the first occurrence of that character within the string.
When you have: chkchr == (answers.substring(0))
You are asking if the value returned by answers.substring(0) is exactly equal to the character code that is presently stored in the variable chkchr. What is it that the method substring(0) is supposed to do that would make this a meaningful comparison? That's why I asked what that function returns when passed 0 as an argument. I don't see any reason to expect that to return the character code for any particular character in the string except, possibly, the first. More likely, I would expect it to return a string that starts with the first character of answers and contains all of then characters from that point on. If this is the case, then it is returning a pointer to a string which you can pretty much guarantee will never be equal to the value stored in chkchr, so I would expect this test to virtually always fail.
33,140
I don't think there would be equality even if "answers" has a single character, because what is returned is going to be a pointer to a string that happens to have one character, not the value of the character.
And random(M) does just as I expected, which means that random(43) will return values in the range [0, 1, ... 41, 42], which is NOT what the TS wants.
flat5
Joined Nov 13, 2008
403
OK. I would have to turn around the check. I did have it that way at first. I did use the reference.
Thank you, djfantasi!
if ( answers.substring(0) == chkchr) ...
Now I'm trying get this correct. first if is ok. Second if does not work. rows come out short.
Code:
if (answers.indexOf(chkchr) != -1  &&  row < 44)
      t = t - 1;
    else if (answers.indexOf(chkchr) != -1  &&  row > 43  &&  row < 89)
     chkAgain = chkAgain+1;
     if (chkAgain == 1) t = t - 1;
    else
flat5
Joined Nov 13, 2008
403
WBahn, yes " is found. The string length is 44. 0-43.
You have to know the 'C' that the Arduino compiler uses.
I guess there are quirks to it. I am starting here. I have no previous experience with "C".
33,140
Okay, if you say that random(43) is, in fact, returning 0 through and including 43 then I guess it is. That goes counter to what every random(N) function I have ever seen does, it goes counter to what djsfantasi said that random(M) function in the Arduino language does, and it goes counter to what the Arduino website says that this function does:
http://www.arduino.cc/en/Reference/random
It also appears that the Arduino language is neither C nor C++, but is rather based on both (which basically means that it is based on C++) with a bunch of Arduino-specific stuff crammed in.
But if you are satisfied that using random(43) gets you the values you want, that is all that matters in the end.
flat5
Joined Nov 13, 2008
403
No, I did use that page to inform myself. On the page:
// print a random number from 0 to 299
randNumber = random(300);
Serial.println(randNumber);
Edit: huh? You are correct. I don't know why I'm getting the ".
I should go to sleep. Now I'm confusing " and =.
Edit: ok, I changed it to random(44) and am now seeing = and " on the screen.
Thank you again, WBahn.
I will try to sleep. It's 3:10 here.
33,140
This has the exact same problem. answers.substring(0) is going to return a pointer to a copy of whatever is in answers. That pointer, which is a memory address, is NOT going to be equal to the value stored in chkchr, which is an ASCII code.
I'm also concerned about whether you are actually creating an instance of your "answers" string object.
When you declare a variable such as
String answers;
does that invoke the constructor, or does it just allocate memory for the reference variable?
I've cleaned up your code below:
Code:
   t = t - 1;
else
      if (chkAgain == 1)
         t = t - 1;
   else
It would be really helpful if you told us what you want the code to do instead of expecting us to figure out what you want the code to do based on code that you've indicated does NOT do what you want it to do.
flat5
Joined Nov 13, 2008
403
Here is all the code. (I'll sleep later)
Code:
// send random Morse code
// has improved random seed
// uses tone/notone instead of external oscillator.
// Plug speaker to Analog pin8 and gnd. Use a resistor or pot in series if you want to. I used 220 ohm.
#include <Arduino.h>
byte signalPin = 13; // will control oscillator speaker
unsigned int wpm = 20;
unsigned int elementWait = 1200 / wpm;
unsigned int row = 43;
unsigned int space = 2; // time between characters. It is good to send the chacters faster than the space between them for practice.
unsigned int pitch = 846; // a volume peak on my sounder. needed because I'm using a 220 ohm resistor in series.
const int morseOutPin = 13;    // For Morse code output
void setup() {
  pinMode(signalPin, OUTPUT);
  pinMode(1, INPUT); // used in random seed routine
  noTone(8);
  pinMode(morseOutPin, OUTPUT);
  Serial.begin(9600);
  menu();
void loop() {
  parser();
void menu() {
  //Serial.println();
  Serial.println("Send a random group of characters for Morse practice");
  Serial.println("Press Spacebar [Enter] to start");
  //Serial.println();
  Serial.println("Enter 's'(value) to adjust letter space (1-whatever)");
  //Serial.println();
  Serial.println("Enter 'w'(value) to adjust wpm (Example: w20)");
  //Serial.println();
  Serial.println("Enter 'p'(value) to set tone pitch <p31-24000 or <0 for off");
  //Serial.println();
  Serial.println("Enter 'r'(value) to set how many characters in the row to send (1-89)");
  //Serial.println();
  Serial.println("Enter 'm' to display this menu");
  //Serial.print();
  Serial.println("Enter 'c' to clear screen on real terminals");
  //Serial.print();
  Serial.print("Currently: s:"); Serial.print(space); Serial.print(" w:"); Serial.print(wpm);
  Serial.print(" r:"); Serial.print(row); Serial.print(" P:"); Serial.println(pitch);
  Serial.println();
void parser()
  unsigned int digits;
  unsigned int value = 0;
  do
    digits = Serial.available();
  while (digits < 1);
  char keypress = Serial.read();
  do
  while
  (digits < 0);
  value = Serial.parseInt();
  Serial.flush();
  switch (keypress)
    case 'm': case 'M': // display menu
        menu();
        break;
    case ' ': // generate code
        random_code();
        break;
    case 's': case 'S': // letter space length
        if (value != 0) space = value;
        Serial.print("Letter space(s) "); Serial.println(space);
        break;
    case 'w': case 'W': // wpm
        if (value != 0) wpm = value;
        Serial.print("wpm: "); Serial.println(wpm);
        break;
    case 'r': case 'R': // how many to send (a row)
        if (value != 0)
          row = value;
        Serial.print(row); Serial.println(" characters will be sent");
        break;
    case 'c': case 'C':
        refresh_Screen(); // a real terminal is required for this to work
        break;
    case 'p': case 'P':
        pitch = value;
        if (pitch == 0)
          pitch = 0;
          noTone(8);
          Serial.println("Tone echo is now off."); // stare at the led
          break;
        if (pitch < 31)
          Serial.println("31 is minimum");
          break;
        if (pitch > 24000)
          Serial.print("24000 is max");
          break;
        Serial.print("Tone pitch in Hz:"); Serial.println(pitch, DEC);
        tone(8, pitch, 400);
        break;
void refresh_Screen()
  Serial.write(27); // ESC
  Serial.write("[2J"); // clear screen
  Serial.write("[H"); // cursor to home
void dit() {
  digitalWrite(signalPin, HIGH);
  if (pitch != 0) tone(8, pitch);
  delay(elementWait);      // milliseconds - one dit
  digitalWrite(signalPin, LOW);
  noTone(8);
  delay(elementWait);
void dah() {
  delay(elementWait * 3);
  noTone(8);
  delay(elementWait);
void letter_space() {
  delay(elementWait * space);
  char* code_char[] =
  char* codes[] =
  for (unsigned int t = 0; t < row - 1 ; t++) // each run will be 'row' characters (+ 'row' spaces) but the last check needs a kludge
    unsigned int randNumber = random(44); // 0 - 43, all characters.
    // see if the randNumber character is in string 'answers'. I remove this check if row > 44
    if (answers.indexOf(chkchr) != -1 && row < 45)
      t = t - 1;
    else
      // I decided I would need another long string to check if a character was repeated more than once.
      // If I want a short run of characters I don't want them to repeat but if the run is >44 it's not so important if they repeat.
      // So I have dropped that check.
    send_char = send_codes[t]; // send the code of a character
    for (unsigned int i = 0; i < send_char.length(); i++) // break it down
      String x;
      x = send_char.substring(i, i + 1);
      if (x == ".") dit(); else dah();
    letter_space();
// This code to develop a random seed is from here: http://www.utopiamechanicus.com/article/arduino-better-random-numbers/
// It is much better than the routine that came with the compiler package.
unsigned int bitOut(void)
  static unsigned long firstTime = 1, prev = 0;
  unsigned long bit1 = 0, bit0 = 0, x = 0, port = 1, limit = 99;
  if (firstTime)
    firstTime = 0;
    prev = analogRead(port);
  while (limit--)
    x = analogRead(port);
    bit1 = (prev != x ? 1 : 0);
    prev = x;
    bit0 = (prev != x ? 1 : 0);
    prev = x;
    if (bit1 != bit0)
      break;
  return bit1;
unsigned long seedOut(unsigned int noOfBits)
  // return value with 'noOfBits' random bits set
  unsigned long seed = 0;
  for (int i = 0; i < noOfBits; ++i)
    seed = (seed << 1) | bitOut();
  return seed;
I'm using a 555 osc. so I turn the tone off. option p=0
I guess I'm happy with this version.
WBahn, I'll look at your rewrite after I get some sleep.
33,140
I didn't rewrite anything, just reformatted it a bit to compensate for the lousy way that the forum editor handles pasted test.
flat5
Joined Nov 13, 2008
403
I'm still learning how to communicate with experienced programmers :)
I thought of a much better way to do that function while trying to sleep.
What I wanted:
if row is 44 or less, allow no repeats (of a character).
if a row is greater than 44 and less than 89 allow one repeat.
I think this is the best way to achieve this.
build 'answers' til 44 characters
if a row is > 44 build 'answers2' till 88 characters (or less) using the same check for repeats.
concat them. 'answers' is now a string of 1 to 88 characters with no more than one repeat of any character.
djsfantasi
Joined Apr 11, 2010
9,237
Strings in Arduino C are different than an array of char in C. The comparison is valid on an Arduino and will succeed if both variables contain the same character value.
flat5
Joined Nov 13, 2008
403
This does what I wanted to accomplish in my last post.
t is not allowed to be > 88
Code:
if (t < 44)
      if (answers.indexOf(chkchr) != -1) t = t - 1;
      else
        answers.concat(code_char[randNumber]); answers.concat(" "); // add a space after each character for readability
        send_codes[t] = (codes[randNumber]); // build array of code character strings to be sent
    if (t > 43)
      if (answers2.indexOf(chkchr) != -1) t = t - 1;
      else
        answers2.concat(code_char[randNumber]); answers2.concat(" ");
  send code
  Serial.print(answers); Serial.println(answers2); Serial.println();
flat5
Joined Nov 13, 2008
403
Updated full code. If you want the last version note the post edit date/time.
I will update the code in this post of the thread.
Code:
// choice of tone/noTone or external oscillator.
void setup() {
  noTone(8);
  Serial.begin(9600);
  menu();
void loop() {
  parser();
void menu() {
  //Serial.println();
  //Serial.println();
  //Serial.println();
  //Serial.println();
  //Serial.println();
  Serial.println("Enter 'r'(value) to set how many characters in the row to send (1-88)");
  //Serial.println();
  //Serial.print();
  //Serial.print();
  Serial.println();
void parser()
  do
  while (digits < 1);
  do
  while
  (digits < 0);
  Serial.flush();
  switch (keypress)
        menu();
        break;
        random_code();
        break;
        break;
        break;
        if (value != 0 && value < 89)
          row = value;
        break;
        else
        {Serial.println("value must be 1-88");
        break;
    case 'c': case 'C':
        break;
    case 'p': case 'P':
        pitch = value;
        if (pitch == 0)
          pitch = 0;
          noTone(8);
          break;
        if (pitch < 31)
          break;
        if (pitch > 24000)
          break;
        break;
void dit() {
  noTone(8);
  delay(elementWait);
void dah() {
  noTone(8);
  delay(elementWait);
  char* code_char[] =
  char* codes[] =
  String send_char; String answers; String answers2;
  char* send_codes[row]; //array starts at 0. User inputs how many characters in a run (row on screen)
  for (unsigned int t=0; t<row; t++) // each run will be 'row' characters (+ 'row' spaces) but the last check needs a kludge
    // see if the randNumber character (chkchr) is in string 'answers' already. I remove this check if row > 44
    if (t < 44)
      else
    if (t > 43 )
      else
      String x;
    letter_space();
  if (firstTime)
    firstTime = 0;
  while (limit--)
    prev = x;
    prev = x;
    if (bit1 != bit0)
      break;
  return bit1;
  return seed;
[/code
33,140
So you're saying that myString.substring(5), for instance, returns an ASCII value if myString has six characters but it returns a reference to a string object if it has more than six?
djsfantasi
Joined Apr 11, 2010
9,237
If you were to execute the line "Serial.print(myString.substring(5))" and myString was "abcdefghij" would you expect a pointer value or "ghij"?
I'm saying that myString.substring(5), for instance, returns a reference to a string object that consists of one character if myString has six characters and it returns a reference to a string object that consists of multiple characters if it has more than six. Look at the examples in the Arduino reference.
