Hi all,
I am struggling trying to troubleshoot the amplification circuit of a Yamaha rx-v870 receiver.
I have checked all transistors using basic diode check and resistors and they seem ok. I am getting wildly fluctuating voltage at the output transistor's emitter.
I am trying to isolate the amplification stage to verify that the output transistors are not leaking. Below is the circuit in question:
To isolate the amplification stage, I have removed Q127 and Q129.
The way I see it, if none of the 6 output transistors are leaking the voltage at Q154 and Q156 emitters should be 0v.
Is this correct?
Or is there something else I should do to find any problems with the output transistors?
Thanks,
Alex
Is this correct?
Thanks,
Alex
