PLC Potentiometer Control
Camarodude28
Joined Jan 8, 2017
12
My train set uses a potentiometer wired as a variable voltage divider to control the speed of the train. The voltage range is from 0 to 26 VDC. I was wondering if there was any way that I could use a PLC to control the speed of the train. The PLC I have is a Micrologix 1000. It does not have any analog outputs or else I would use those. I was possibly thinking of using a digital potentiometer but I am not sure if that would work. Any help would be appreciated. Thanks.
Ryan
MaxHeadRoom
Joined Jul 18, 2013
30,654
What do you intend to achieve with a PLC?
Even if it had a analogue module?
Not sure what current train controllers are, maybe PWM?
I have an old SCR design by GE for a Model RR speed controller with rev. capability..
Max.
Reloadron
Joined Jan 15, 2015
7,888
While 0 to 26 VDC is nice to know you need to know the current the train requires. The reason a potentiometer was used is likely because it was the simple solution. Per Max you could look at maybe a PWM solution or SCR solution but why?
Ron
Camarodude28
Joined Jan 8, 2017
12
Max.
I am trying to automate my trains to go around the track and perform other tasks by themselves and without me needing to flip switches. My trains require 0.7A of current according to my original controller.
MaxHeadRoom
Joined Jul 18, 2013
30,654
If you want to use automation, then a Smart Relay is one possible answer, small version of a PLC, they have a real time clock that could provide schedules etc, for accel control a ramp up into a SCR type control could be used.
Max.
Camarodude28
Joined Jan 8, 2017
12
Is there any way that I could do this with the PLC? I was able to get one from work to use and I really don't want to have to buy anything else for this project being that it is just something for me to tinker around with. Thanks
MaxHeadRoom
Joined Jul 18, 2013
30,654
The Micrologix just comes with digital output, not sure if they have an analogue module as an add on.
The logic side will be OK for automating switching however.
But you would need integration of the speed controller which would be external to the PLC even if a analogue module Was available..
Max.
Reloadron
Joined Jan 15, 2015
7,888
Page 5-3 of the manual does mention a single analog out channel. You can have 0 to 10 V or 4 to 20 mA and that looks to be about it as to analog out.
The analog input channels are single–ended (unipolar) circuits and can be individually enabled or disabled. The default is all input channels enabled. The two voltage inputs accept ±10.5V dc, and the two current inputs accept ±21 mA. The analog output channel is also a single–ended circuit. You can configure either voltage (0V dc to +10V dc) or current (+4 to +20 mA) output operation. The default is voltage output. The output must be configured for either voltage or current, not both. This is determined by the output configuration. When in the Run mode and the output is configured for voltage, the voltage output terminal is active and the current output terminal is inactive. Similarly, when in the Run mode and the output is configured for current, the current output terminal is active and the voltage output terminal is inactive. When the system is not in Run mode, both the voltage and current outputs are inactive.
Ron
