PLC input/output design
Axel_sr
Joined Feb 28, 2022
50
Hi. I have been iterating different options for PLC-level digital inputs and outputs. If you have good practices in mind, I appreciate to hear about them. It does not matter if those are related to 5VDC symmetric signal output, or 24VDC OC output, or something else (except relay).
A
And for those who ask the question "can't help you without more specific specs" I answer that there are no specs or requirements. This is more about learning about what kind of solutions there are inside of "real" PLCs.
Papabravo
Joined Feb 24, 2006
22,111
For Digital inputs we use LM339 (quad) or LM393 (dual) open collector comparators. Input resistors are large to limit input current.
For digital outputs we used bipolar high side switch with D-PAK transistors.
It is entirely possible that a similar MOSFET circuit would work as well and cost less to boot.
panic mode
Joined Oct 10, 2011
5,204
exactly.... isolation is important. you do not want single fault or wiring mistake to to take down multiple pieces of equipment. also some of them will use different polarity IO. i prefer to not be constrained or having to add different type of IO module.
MaxHeadRoom
Joined Jul 18, 2013
30,791
At one time, for custom PLC type applications, I used the Opto-22 I/O isolated modules, They come in various configurations, 5v & 24v, with AC & DC outputs which had LED indicators and fusing etc.
e.g. of just two types.
MaxHeadRoom
Joined Jul 18, 2013
30,791
Not really, they are SS modules,
This is typical output style, later ones had both LED and fusing on the module itself..
Triac output:
