How is 30 V pk-pk 30 W?
28.125W, my bad Mr. Literal.
Not sure I like your attitude.Quit mixing subscripts.
What subscripts? Instead of being an a**hole for the sake of it, how bout being helpful.subscripts
How so? It says right on the screen. 15v phase peak across 8 ohms = 1.875A or 28.125W. Ohms law.28.125W is not correct either.
You are in the back of a very long line of those who called me that. Now that you asked for help on this specific item, here goes:Instead of being an a**hole for the sake of it, how bout being helpful.
I have a difficult time understanding the way you speak, I'm going to assume english is not your first language.Since the beginning, just the letter indicates rms when talking alternating waves. If your using pk or pk-pk, your answer must have that subscript.
Therefore, 15V pk^2 / 8 ohms = 28.125 W pk.
15 volts peak = 10.605 V. 10.605V^2 / 8 ohms = 14.058 W roughly.
The option you are required to use is your brain.
There are 28.125 Watts peak delivered to the load, NOT 28.125 Watts.There is 28.125W of power being dissipated into the 8 ohm load that I've shown above, therefore the amplifier is outputting 28.125W of power.
Yeah I get it now, updated my previous post. I wasn't sure how people classified output power exactly, it's never really been an point of interest for me.There are 28.125 Watts peak delivered to the load, NOT 28.125 Watts.
I did read the spec sheet. I don't understand why any amplifier needs to pump out that much power. What uses that much power, ribbons maybe?However, if you bothered to open the satirical specification sheet I posted, you will see what that amplifier can do and what the customer who gets it repaired wants in returned to do
It's not being literal, it's being accurate.8.125W, my bad Mr. Literal.
You seem to be the one with the crappy arrogant attitude.Not sure I like your attitude.
The FFT plot in post #57 doesn't seem to square with those figures. The peak is at 0dB.Anyway I gave a speaker amp more thought and this is the result
30vp-p into 8 ohms or about 30W.
I said it was "about" 30W. This implies not exactly 30W. The difference was not big enough for me to care.It's not being literal, it's being accurate.
You are welcome to you own opinion, but not your own facts.
You seem to be imagining things.You seem to be the one with the crappy arrogant attitude.
Very nice. Respect.This compares favourably with your post #57 plot. A ~20dB lower noise floor. As you'll appreciate, the circuit is confidential .
Seems right to me. It was working in unity @ 30vp-p. I only whipped up that design for a quick demonstration, haven't managed to get it stable @ 30x gain yet, it's far from being optimized. It's designed to cancel its own distortion so I expect barely any, if any change in distortion when get it functioning @ 30x gain.The FFT plot in post #57 doesn't seem to square with those figures. The peak is at 0dB.
Touche again, very nice.Here's the FFT for 60V pk-pk and 8Ω load :
How could you ever find speakers worthy of that?!On edit ... For the low sum of $57000, you could own this ... http://dandagostino.com/products/momentum-integrated.php. In the box you get a pair of white lifting gloves.
by Jake Hertz
by Aaron Carman
by Aaron Carman
by Jake Hertz
