PIR sensor (D203S) on breadboard
kzsolt87
Joined Jul 13, 2023
23
Hi All,
I spent the last two days on trying to condition the signal of a PIR sensor - D203S - on my breadboard without luck. I was following the circuit described on https://www.st.com/resource/en/appl...e-infrared-pir-sensors-stmicroelectronics.pdf however it's not working for some reason.
My question is that anyone had any luck getting PIR sensor working on breadboard? I heard it's very noisy, so was thinking it might be the reason I'm unable to get this circuit working
ericgibbs
Joined Jan 29, 2010
21,463
Hikz,
A regular PIR sensor relies on the Fresnel lens in order to create a low frequency signal voltage.
Look at this PDF, note the pattern created by the lens.
Please post a photo of your PIR project board.
E
27,679
Does the TS have anything to examine the waveform of the IR device and the voltages within the circuit? Consider that attempting to do any diagnostics with no information is depending on a very lucky guess, we do need to know what resources the TS has available.
kzsolt87
Joined Jul 13, 2023
23
Ok.. fair point, sorry did not put this info earlier. So I have a handheld scope and tried to check the signal while providing 6VDC to the circuit. I measure ~700mW after sensor and after stage 1 / 2. I can also see a 160-320mW pp noise. so maybe the sensor is working, but I have too much noise so cant really see it. Will take a picture of scope output too. Thanks
kzsolt87
Joined Jul 13, 2023
23
Seems like its a faulty PIR sensor after all. I had 3 of them, tried two - same result. I tried the 3rd one now and its working… Now Im thinking how did I blew the other two… Can I damage it if I “forget” to put a current limiting resistor and connect it directly to VCC?
