pin order on a chip based on text
BobTPH
Joined Jun 5, 2013
11,667
There should be some kind of dot near pin 1 or a notch on the side to the left of pin one.
Post a photo if the actual chip.
Jon Chandler
Joined Jun 12, 2008
1,658
The datasheet appears to show a dot near pin 1 (a slightly recessed hole usually) and a bevel is common on surface mount packages.
I was just thinking.... I don't think I've ever seen a DIL (Dual In Line) package where the text is not right-side-up when pin 1 is at the lower left. Has anyone observed otherwise?
28,517
Rather than make random guesses based on what we see on other devices, note on the data sheet that pins 5 thru 8 are all DRAIN pins tied to each other. I am thinking that should be possible to verify with an OHM METER.
ALSO NOTE that pins #1, #2, and #3 are the three source pins, apparently tied together. Pin #4 being the Gate pin, should have a higher resistance to the other pins. So with a simple OHM METER check it should be possible to verify which side is the four drain connections. ALSO, note that pins #4 and #5 are the ones spaced farther from the others, IF the data sheet is correct.
IN fact, the data sheet does display a top view with both pin numbers and pin designations given.
