PIC18F4550 Interfacing with LCD using XC8 compiler
devilarm123
Joined Dec 26, 2017
33
Here is a new 'init' routine. Note that I do not have your hardware so this is untested code.
C:
void lcd_init(void)
TRISD = 0x00;
LATD = 0x00;
LCD_RS = 0; // write control bytes
__delay_ms(15); // power on delay
lcd_write_cmd(0x30);
__delay_ms(5);
__delay_us(100);
__delay_ms(5);
lcd_write_cmd(0x20);// set 4 bit mode
__delay_us(40);
lcd_write_cmd(0x28); // 4 bit mode, 1/16 duty, 5x8 font
lcd_write_cmd(0x08); // display off
lcd_write_cmd(0x0F); // display on, blink curson on
lcd_write_cmd(0x06); // entry mode
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
make[1]: Entering directory 'C:/Users/Angus/Desktop/draft2.X'
make -f nbproject/Makefile-default.mk dist/default/production/draft2.X.production.hex
make[2]: Entering directory 'C:/Users/Angus/Desktop/draft2.X'
"C:\Program Files (x86)\Microchip\xc8\v1.35\bin\xc8.exe" --pass1 --chip=18F4550 -Q -G --double=24 --float=24 --emi=wordwrite --opt=default,+asm,+asmfile,-speed,+space,-debug --addrqual=ignore --mode=free -P -N255 --warn=-3 --asmlist --summary=default,-psect,-class,+mem,-hex,-file --codeoffset=100 --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,-download,+config,+clib,-plib --output=-mcof,+elf:multilocs --stack=compiled:auto:auto:auto "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" -obuild/default/production/lcd_utilities.p1 lcd_utilities.c
lcd_utilities.c:21: error: (255) not a member of the struct/union ""
lcd_utilities.c:21: error: (182) illegal conversion between types
int -> volatile union S271
lcd_utilities.c:51: error: (255) not a member of the struct/union ""
lcd_utilities.c:51: error: (182) illegal conversion between types
make[2]: *** [build/default/production/lcd_utilities.p1] Error 1
make[1]: *** [.build-conf] Error 2
(908) exit status = 1
nbproject/Makefile-default.mk:126: recipe for target 'build/default/production/lcd_utilities.p1' failed
make[2]: Leaving directory 'C:/Users/Angus/Desktop/draft2.X'
nbproject/Makefile-default.mk:78: recipe for target '.build-conf' failed
make[1]: Leaving directory 'C:/Users/Angus/Desktop/draft2.X'
make: *** [.build-impl] Error 2
nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
BUILD FAILED (exit value 2, total time: 613ms)
I tried and I got this error code, Im also currently testing the lcd_write_string
devilarm123
Joined Dec 26, 2017
33
Which lines did it indicate were wrong?
Looks like lines 21 and 51 of lcd_utilities.c
C:
void lcd_write_cmd(unsigned char cmd)
    unsigned char temp2;
    LCD_RS = 0;                    // Select LCD for command mode  [B]<-- line 21[/B]
    __delay_ms(4);                // 40us delay for LCD to settle down
    temp2 = cmd;
    temp2 = temp2 >> 4;            // Output upper 4 bits, by shifting out lower 4 bits
    temp2 = temp2 & 0x0f;
    LATD = LATD & 0xf0;
    LATD = LATD | temp2;        // Output to PORTD which is connected to LCD
    __delay_ms(8);            // 10ms - Delay at least 1 ms before strobing
    lcd_strobe();
    __delay_ms(8);            // 10ms - Delay at least 1 ms after strobing
    temp2 = cmd;                // Re-initialise temp2
    LATD = LATD & 0xf0;
    LATD = LATD | temp2;        // Mask out upper 4 bits
    lcd_strobe();
//---- Function to write a character data to the LCD ---------------------------
void lcd_init(void)
TRISD = 0x00;
LATD = 0x00;
LCD_RS = 0; // write control bytes [B]<-----51[/B]
__delay_ms(5);
__delay_us(100);
__delay_ms(5);
__delay_us(40);
Moderators note : Please use code tags for code=c to annotate C code.
devilarm123
Joined Dec 26, 2017
33
If the LCD is displaying single characters correctly then the lcd_init( ) is supposedly working.
You cannot write a string to the LCD using lcd_write_data(i) on its own. You need another function to write an entire string.
Check the lcd.h file for the appropriate function. If it does not have the string function you can write your own.
C:
void lcd_write_string(char *s)
  while (*s) lcd_write_data(*s++);
I added the code like you said in the lcd.h
I just dont know why the lcd doesnt initiate properly, could delay be the problem?
C:
void main(void)
char *s="mapp";
  lcd_init();
  lcd_write_cmd(0x01);
  lcd_write_cmd(0x80);
  lcd_write_string(*s);
35,233
You need to take one step at a time.
Is the lcd_init( ) function working?
C:
void main(void)
  lcd_init();
  lcd_write_data('A');
35,233
If that code works, you can try repeatedly sending the same character forever.
C:
void main(void)
  lcd_init();
  while (1)
    __delay_ms(500);
35,233
Next, you can try outputting a string.
C:
char message[] = "Hello World!";
  while(*s) lcd_write_data(*s++);
void main(void)
  lcd_init();
  lcd_write_string(message);
devilarm123
Joined Dec 26, 2017
33
C:
void main(void)
  lcd_init();
while the first two code works without a problem, the 3rd one is runnable, but lcd is constantly displaying spaces and not the message[]
35,233
Try the following:
C:
#include <string.h>
void main(void)
  char message [20];
  strcpy(message, "Hello World!"];
  lcd_init();
35,233
How do you know that the LCD does not initialize?
If the codes that I posted in post #25 and #26 are working then your LCD is initialized.
devilarm123
Joined Dec 26, 2017
33
I've tried a number of times,
This is what I observed:
  1. #include <string.h>
  2. void lcd_write_string(char *s)
  3. {
  4. while(*s) lcd_write_data(*s++);
  5. }
  6. void main(void)
  7. {
  8. char message [20];
  9. strcpy(message, "Hello World!");
  10. lcd_init();
  11. lcd_write_string(message);
  12. }
Above code is runnable but the lcd doesnt show or display.
But,
  3. {
  5. }
  6. void main(void)
  7. {
  9. strcpy(message, 'c' );
  10. lcd_init();
  12. }
Above code is runnable and lcd displays something(as attached).
It's always the ' ' and " " being an issue, is it possible that lcd cant read strings directly? or something wrong with the delay
Ian Rogers
Joined Dec 12, 2012
1,136
I just simulated the "unchanged" code at 20Mhz REMOVED the "delay utilities" (Not needed ) changed the delay in main to __delay_ms(1000)and it runs fine..
AlbertHall
Joined Jun 4, 2014
12,653
Did you check that when data is being written to the display that RS retains its value?
The init routine is wrong so I don't think that will work with the actual display.
Ian Rogers
Joined Dec 12, 2012
1,136
In his "unchanged code" RS is reset after the temp shift so it works.... The 48Mhz was an issue and there was a problem with all the delay reconfiguration…. I deleted the utilities code as it was superfluous.. Works as expected..
AlbertHall
Joined Jun 4, 2014
12,653
And the LCD is correctly initialised?
35,233
Add the while(1); statement to your code.
C:
#include <string.h>
void main(void)
  char message [20];
  lcd_init();
  while(1);
devilarm123
Joined Dec 26, 2017
33
man if it works, I'm really thankful.
Could you tell me how exactly u did it? do I add a configuration file to my code?
