PIC18 - Flash memory - erase
bug13
Joined Feb 13, 2012
2,002
You enable interrupts - do you actually have any? I realize that we're looking a just a piece of the code but if you don't and you enable IRQs *boom*
I do have interrupt.
  • system ticks, and
  • uart rx, this rx just receive char into a buffer untill CR is received, than flag it as ready. mainly for debug at this stage.
Code:
void interrupt ISR(void){
    // timer2 interrupt, system tick
    if (PIR1bits.TMR2IF == 1){
        // clear interrupt flag
        PIR1bits.TMR2IF = 0;
        // increase ticks
        systemTicks++;
    // uart rx interrupt
    if (PIR1bits.RCIF == 1){
        PIR1bits.RCIF = 0;
        // if error, clear them
        if (RCSTAbits.FERR || RCSTAbits.OERR){
            RCSTAbits.CREN = 0;
            RCSTAbits.CREN = 1;
        else{
            // read data
            static uint8_t data;
            data = RCREG;
            // if buffer is available
            if (uartRXBuff.isReady == 0){
                // if this is the end of a packet
                if (data == '\r'){
                    uartRXBuff.isReady = 1;
                else{
                    // check of overflow
                    if (uartRXBuff.ptr >= UART_RX_BUFF_LEN)
                        uartRXBuff.ptr = 0;
                    uartRXBuff.data[uartRXBuff.ptr++] = data;
JohnInTX
Joined Jun 26, 2012
4,787
I check the operation by reading out firmware with IPE, export it to a HEX file, and inspect it with notepad++
Are you taking into account any type 04 Linear Address Records in the .HEX? That could affect what you think you are reading. I'd try to read the chip then inspect the Program Memory in IPE itself.
OK on the interrupts.
JohnInTX
Joined Jun 26, 2012
4,787
Try this?
C:
 * File:  Bug13.c
 * Author: John
 * Created on February 18, 2018, 6:34 PM
// PIC18F44J10 Configuration Bit Settings
// 'C' source line config statements
// CONFIG1L
#pragma config WDTEN = OFF  // Watchdog Timer Enable bit (WDT disabled (control is placed on SWDTEN bit))
#pragma config STVREN = ON  // Stack Overflow/Underflow Reset Enable bit (Reset on stack overflow/underflow enabled)
#pragma config XINST = OFF  // Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
// CONFIG1H
#pragma config CP0 = OFF  // Code Protection bit (Program memory is not code-protected)
// CONFIG2L
#pragma config FOSC = ECPLL  // Oscillator Selection bits (EC oscillator, PLL enabled and under software control, CLKO function on OSC2)
#pragma config FOSC2 = ON  // Default/Reset System Clock Select bit (Clock selected by FOSC as system clock is enabled when OSCCON<1:0> = 00)
#pragma config FCMEN = ON  // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor enabled)
#pragma config IESO = ON  // Two-Speed Start-up (Internal/External Oscillator Switchover) Control bit (Two-Speed Start-up enabled)
// CONFIG2H
#pragma config WDTPS = 32768  // Watchdog Timer Postscale Select bits (1:32768)
// CONFIG3H
#pragma config CCP2MX = DEFAULT // CCP2 MUX bit (CCP2 is multiplexed with RC1)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include <xc.h>
// shows up in .HEX as
// :090800003132333435363738004B
const unsigned char junk[] @0x800 = "12345678";
void flashEraseBlock(unsigned char addr){
  The sequence of events for erasing a block of internal
  program memory location is:
  1. Load Table Pointer register with address of the
  block being erased.
  2. Set the WREN and FREE bits (EECON1<2,4>)
  to enable the erase operation.
  3. Disable interrupts.
  4. Write 55h to EECON2.
  5. Write 0AAh to EECON2.
  6. Set the WR bit. This will begin the erase cycle.
  7. The CPU will stall for duration of the erase for
  TIE (see parameter D133B).
  8. Re-enable interrupts.
  The Most Significant 7 bits of the
  TBLPTR<21:10> point to the block being erased.
  TBLPTR<9:0> are ignored.
  *  Block 0 = 0000H - 0399H
  *  Block 1 = 0400H - 0799H
  *  etc...
  // load the address into pointer registers
  TBLPTRU = 0;
  TBLPTRH = 0x08;
  TBLPTRL = 0;
//  TBLPTRU = 0;
//  TBLPTRH = (block << 2);
//  TBLPTRL = 0;
//  TBLPTRU = (block >> 2);
//  TBLPTRH = (block << 6);
//  TBLPTRL = 0;
  //printf("TBLPTR: %02X %02X %02X\n", TBLPTRU, TBLPTRH, TBLPTRL);
  //return;
  // enable erase operation
  EECON1bits.WREN = 1;
  EECON1bits.FREE = 1;
  // disable interrupt
  di();
  // unlock erase
  EECON2 = 0x55;
  EECON2 = 0xAA;
  // start the process
  EECON1bits.WR = 1;
  ei();
  //printf("DONE!\n");
void main(void)
  unsigned char i;
  i = 1;
  flashEraseBlock(i);  // not used yet
  while(1);
This works on MPSIM. You can see the dummy data in the .HEX from the compile (bold text). Keep in mind that IPE may not re-generate any .HEX record for erased data.
:0400000013EF04F006
:020400000000FA
:10080A00F86A080EF76EF66AA684A688F29E550E56
:10081A00A76EAA0EA76EA682F28EAA0C000EF86E1A
:0C082A00000118EF04F005EC04F0FFD70B
:063FF800A0F4C7FFFFF179
:00000001FF
JohnInTX
Joined Jun 26, 2012
4,787
@bug13 In IPE go to Advanced Mode to select View->Show Memory. Right-click inside the memory window and click Undock. You'll get a full screen view. Here's the memory at 800h from the code above. Read the chip after running the code and you should see all FFFF at 800h+ Remember you can only run it once for each loading of the .HEX and programming of the chip.
bug13
Joined Feb 13, 2012
2,002
So I tested your code in a new project, and read the firmware back, here is what I got. (File attached).
I can't tell if the right block is erased or not, I will prefill some data and have another test.
bug13
Joined Feb 13, 2012
2,002
@JohnInTX
So I start with your code, fill in more junk 1 block before and after 0x0800, and the code seem to work perfectly (I have attached my before and after hex files). Now I need to find out what in my code to screw my block erase up.
Code:
* File:  Bug13.c
* Author: John
// CONFIG1L
// CONFIG1H
// CONFIG2L
// CONFIG2H
// CONFIG3H
#include <xc.h>
const unsigned char junk1[] @0x400 = {
    0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55,
const unsigned char junk2[] @0xC00 = {
  block being erased.
  *  etc...
  TBLPTRU = 0;
  TBLPTRH = 0x08;
  TBLPTRL = 0;
//  TBLPTRU = 0;
//  TBLPTRL = 0;
//  TBLPTRL = 0;
  //return;
  di();
  // unlock erase
  EECON2 = 0x55;
  EECON2 = 0xAA;
  EECON1bits.WR = 1;
  ei();
void main(void)
  unsigned char i;
  i = 1;
  while(1);
JohnInTX
Joined Jun 26, 2012
4,787
@bug13 A couple of things to consider,
Build in MPLABX for MPSIM and do a test call of the erase function right after init. Set a breakpoint and examine TBLPTR in the SFR PIC Memory Views to be sure your arithmetic is OK.
Next, since it's just a const array in ROM, you can read it and print it as hex before and after the erase to verify its operation. In practice, you would want to verify anyway to verify that your update was successful.
Progress!
JohnInTX
Joined Jun 26, 2012
4,787
@bug13 Do these initial tests with code protection turned OFF. Internal operations like reading and printing the ROM data will work but IPE can't read the chip if it's code protected.
NOTE: I used your code to do it
bug13
Joined Feb 13, 2012
2,002
Hi John,
Thanks for your help, really appreciate it.
I think I got it working now, I think the reason I can't get it to work is the combination of bad data sheet, and I am having a "senior" moment. I believe my code works after using your suggestion.
But when I read the firmware back and view it in notepad++, it shows a block from 013xH - 0BFFH was all 0xFF, and I read that as the address from 013xH - 0BFFH was erased. But actually only 0800H - 0BFFH was erased, from 013xH - 07FF was already 0xFF for some reason.
I hope I explained it clearly???
There is the original hex file generated by the compiler:
Code:
:1000F80010C0F5FF0FC0F8FF0EC0F7FF0DC0F6FFE8
:100108000CC0F4FF0BC0F3FF0AC0DAFF09C0D9FF27
:1001180008C0E2FF07C0E1FF06C0EAFF05C0E9FF2B
:1001280004C0FBFF03C0FAFF5F921100F8EF0CF068
:10080000AAAAAAAAAAAAAAAABBBBBBBBBBBBBBBBC0
:10081000AAAAAAAAAAAAAAAABBBBBBBBBBBBBBBBB0
:10082000AAAAAAAAAAAAAAAABBBBBBBBBBBBBBBBA0
:10083000AAAAAAAAAAAAAAAABBBBBBBBBBBBBBBB90
:10084000AAAAAAAAAAAAAAAABBBBBBBBBBBBBBBB80
Here is how it looks like after I read the firmware back:
Code:
:100100000EC0F7FF0DC0F6FF0CC0F4FF0BC0F3FFED
:100110000AC0DAFF09C0D9FF08C0E2FF07C0E1FF4B
:1001200006C0EAFF05C0E9FF04C0FBFF03C0FAFFF9
:100130005F921100F8EF0CF0FFFFFFFFFFFFFFFFE2
:10014000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBF
:10015000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAF
:10016000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9F
:10017000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8F
PS: CP was off
bug13
Joined Feb 13, 2012
2,002
I only start to realize this mistake after adding one block of pre-filled data before and after the block I want to erase, because the pre-filled data before and after make it clear.
JohnInTX
Joined Jun 26, 2012
4,787
That's because the programmer does a bulk-erase and that block would look like your purposely-erased block.
And I agree on the databook. When I read it, I thought it was a new way of doing it. But looking at my old code and @takao21203 's comments, I realized it was just as before. I probably didn't understand the databook then either but figured it out.
Good deal! Thanks for the update. It was a good review for me, too.
