I need help with PIC18
Kagan_x
Joined Apr 4, 2021
9
Hey I'm new in here.
I have a problem.
I want to write a program. I designed a hardware and software for monitoring button connected to use PORTB. If there is press on buton then turn LED on. If you no press on the button the turn LED off.
So, I write code and I designed circuit to proteus.
Problem is LED always lights up.
When I do not press on button, LED is on, When I do press on button still LED is on. LED is always lights up.
I attach here two picture. Codes and circuits.
What is problem? is there anyone who can help
I use PIC18F45K22
AlbertHall
Joined Jun 4, 2014
12,652
Note the extract below from the datasheet. So at power up RB3 will be an analog input and it will read '0' telling the program that the button is pressed. To fix this you can set the PBADEN config bit which will disable all analog input on PORTB, or you can set bit 3 of ANSELB as part of the pin setup section of your code.
There is no analog capability on RC0 so that is OK.
Kagan_x
Joined Apr 4, 2021
9
The firstly, thank you for help. I'm beginner to microcontroller.
How can I set the PBADEN config settings ?
Kagan_x
Joined Apr 4, 2021
9
In the CONFIG3H section add the line
CONFIG PBADEN = OFF
Thank you for everything. I changed config settings, I did turn on after it is working.
But I still have a problem.
My friend wrote same code and he designed circuit. everything is same. (Ports, bits..)
My friend config set is CONFIG PBADEN = ON, but if he simulation circuit on protheus, circuit is working properly.
I did not understand. codes are same circuit is same, CONFIG PBADEN = ON, there is no problem, but my config is ON doesnt working.
what could be the reason for this ?
AlbertHall
Joined Jun 4, 2014
12,652
Maybe something IS different or maybe this is something to do with simulator settings. I don't know that simulator so I really can't comment on that.
Kagan_x
Joined Apr 4, 2021
9
I have a another problem.
I want to light up 2 led, I wrote code.
When I simulation code on proteus, only one led lights up.
But if I use different ports, code is working properly.
So, if I use PORTB for 2 led only one is light up. other doesn't work.
but I use PORTB to led1 and use PORTC to led2 code is working.
I attached codes, what is problem ?
AlbertHall
Joined Jun 4, 2014
12,652
Do you have the PBADEN turned off?
When you have two LEDs on port B, which pin is the one that doesn't work connected to?
Please attach all the code, preferably in code tags as below:
the word 'CODE' in square brackets
some code here
After the code '/CODE in square brackets.
Kagan_x
Joined Apr 4, 2021
9
Thank you so much, I try PBADEN turned off after it is working properly.
I'm beginner to microcontrollers. So, how can I improve myself about microcontrollers.
If you dont mind could you give me advise for develop myself, for example a book, platform or website.
And what is PBADEN, if it is ON or OFF what is difference ? I dont know what is for. How can I learn this settings
I am thankful fot your help
AlbertHall
Joined Jun 4, 2014
12,652
Search the datasheet for PBADEN.
I learnt my initial programming on the Sinclair Spectrum and got a job on the strength of that. Then I learnt as I went along - Commodore Pet, an HP compiter which used basic and had an IEEE488 interface built in and so on.
Kagan_x
Joined Apr 4, 2021
9
I have a problem, I wrote a simple code. When I debug proje, output is not correct.
I attached code and picture.
Code:
LIST    P=18f45k22
INCLUDE    "P18f45k22.INC"
ORG 0X00
    CLRF TRISB
    CLRF TRISC
    MOVLW 0X55
    MOVWF PORTB
    MOVWF PORTC
    COMF PORTB, F
    COMF PORTC, F
    END
my friend wrote same code, outputs are different again. But my teacher output is correct.
AlbertHall
Joined Jun 4, 2014
12,652
The first thing that strikes me is that the COMF instruction will read the value of the port register, complement it, and write the value back again.
This will hit the analog input problem again so PBADEN is needed.
It will also hit the read-modify-write problem.
Another solution would be to write to, and complement the LATB and LATC registers. That gets around both problems and is better programming practice.
Kagan_x
Joined Apr 4, 2021
9
But my teacher wrote same code, code is working correct. I attached a picture.
He did not use PBADEN ( PBADEN = ON) . just write same code and click debug.
Maybe my Program MPLAB is not working properly ?
what is problem do you think ?
AlbertHall
Joined Jun 4, 2014
12,652
Reading datasheets is a very good place to start.
Then learn by doing and ask questions about what you don't understand or what doesn't work.
You should realise that all the 'experts' here were not born as experts. We have all learnt. My first explorations were with valves (aka vacuum tubes). It's a long walk from there to microcontrollers!
