I've been trying to figure out what in the world is wrong with my program
Im using a PDIP/SOIC package...
Please help me try to analyze it... well first of all, the program is intended to control a motor.
2 sensors(LDR) are attached to RB4(pin10) and RB5(pin11) for sensor1 and sensor2, respectively..
The program intends to check if someone passes through sensor1, if someone does, it will signal the motor to activate on a clockwise basis. afterwhich, if sensor2 detects that someone passes thru, the motor will activate and will revolve on a counterclockwise basis.
this is actually a drawbridge.. please help me..
FYI. The upcount and downcount refers to a counter that tells the user how many passed through sensor1 and will decrement every after someone passes through sensor 2. This isn't really the big prob..the big prob is why it isnt signalling the motor to start
I have tried checking out some newbie guides but still its not working.. please help me.
;REVISED PRIOR TO SUGGESTIONS
i found out a redundancy of my declared characters and a few inconsistencies. my bad, i think i was really having a huge headache last night trying to figure it out.. would you please try to check if it will be good now?
;THE PROGRAM.
processor 16f84
include <p16f84.inc>
OPTION_REG.7=0 (set weak pullup on portB)
__config _XT_OSC&_WDT_OFF&_PWRTE_ON
; Here we define our own personal registers and give them names ;
cblock 0ch
j
ones
;z
endc
errorlevel-302
; Here we give names to some numbers to make their use more clear ;
#define _in PORTB,4
#define _out PORTB,5
#define for PORTB,6
#define rev PORTB,7
#define _1 PORTA,2
; We set the start of code to originate at location zero ;
org 0
; Initialization routine sets up ports and timer ;
clrf ones
bsf STATUS,RP0
movlw b'11000' ;
movwf TRISA
movlw b'00110000' ;
movwf TRISB
bcf STATUS,RP0
call delay
; Main routine ;
main:
call check1
btfsc _in
goto upcount
btfsc _out
goto downcount
goto main
check1:
movf ones,w
sublw .0
btfss STATUS,Z
goto up_tulay
goto down_tulay
check:
btfsc _out
goto check
btfsc _in
goto check
goto main
;bridge up
up_tulay:
bsf for
bcf rev
return
;bridge down
down_tulay:
bcf for
bsf rev
return
; Increments the display up to D'9' ; ;
upcount:
incf ones,F
movf ones,w
sublw h'0A'
btfss STATUS,Z
goto check
clrf ones
goto down_only
; Decrements the display up to D'0' ; ;
downcount:
decf ones,F
movf ones,w
sublw .255
btfss STATUS,Z
goto check
goto up_only
up_only:
movlw .0
movwf ones
call check1
btfsc _in
goto check_up1
btfsc _out
goto up_only
check_up1:
btfsc _in
goto upcount
goto check_up1
down_only:
movlw .9
movwf ones
call check1
btfsc _out
goto check_down1
btfsc _in
goto down_only
check_down1:
btfsc _out
goto downcount
goto check_down1
return
delay:
movlw h'ff'
movwf j
decfsz j,f
goto $-1
return
end
movf ones,w
sublw .0
btfss STATUS,z
goto up_tulay
goto down_tulay
;THE PROGRAM.
processor 16f84
cblock 0ch
j
ones
;z
endc
errorlevel-302
#define _in PORTB,4
#define for PORTB,6
#define rev PORTB,7
#define _1 PORTA,2
org 0
clrf ones
bsf STATUS,RP0
movlw b'11000' ;
movwf TRISA
movlw b'00110000' ;
movwf TRISB
bcf STATUS,RP0
call delay
; Main routine ;
main:
call check1
btfsc _in
goto upcount
btfsc _out
goto downcount
goto main
check1:
movf ones,w
sublw .0
btfss STATUS,Z
goto up_tulay
goto down_tulay
check:
btfsc _out
goto check
btfsc _in
goto check
goto main
;bridge up
up_tulay:
bsf for
bcf rev
return
;bridge down
down_tulay:
bcf for
bsf rev
return
upcount:
incf ones,F
movf ones,w
sublw h'0A'
btfss STATUS,Z
goto check
clrf ones
goto down_only
downcount:
decf ones,F
movf ones,w
sublw .255
btfss STATUS,Z
goto check
goto up_only
up_only:
movlw .0
movwf ones
call check1
btfsc _in
goto check_up1
btfsc _out
goto up_only
check_up1:
btfsc _in
goto upcount
goto check_up1
down_only:
movlw .9
movwf ones
call check1
btfsc _out
goto check_down1
btfsc _in
goto down_only
check_down1:
btfsc _out
goto downcount
goto check_down1
return
delay:
movlw h'ff'
movwf j
decfsz j,f
goto $-1
return
end
movf ones,w
sublw .0
btfss STATUS,z
goto up_tulay
goto down_tulay
