Pic12f1572 delay function
franklin75
Joined Jun 11, 2016
14
Hi everyone!
I am studying pic which is 12f1572 and i use mplab xc8 compiler so firstly i started blink led but i encountered some problems about delay function.my problem is delay function is not work.i confugurate osccon register and i use internal oscilator .thanks for your help
AlbertHall
Joined Jun 4, 2014
12,347
What delay routine did you use - the XC8 ones or something else?
Post the source code please and can you be more specific in what way it is not working.
franklin75
Joined Jun 11, 2016
14
C:
#include <xc.h>
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
// CONFIG1
#pragma config FOSC = INTOSC   //  (INTOSC oscillator; I/O function on CLKIN pin)
#pragma config WDTE = OFF       // Watchdog Timer Enable (WDT disabled)
#pragma config PWRTE = OFF      // Power-up Timer Enable (PWRT disabled)
#pragma config MCLRE = ON      // MCLR Pin Function Select (MCLR/VPP pin function is digital input)
#pragma config CP = OFF         // Flash Program Memory Code Protection (Program memory code protection is disabled)
#pragma config BOREN = OFF      // Brown-out Reset Enable (Brown-out Reset disabled)
#pragma config CLKOUTEN = OFF   // Clock Out Enable (CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin)
// CONFIG2
#pragma config WRT = OFF        // Flash Memory Self-Write Protection (Write protection off)
#pragma config PLLEN = OFF      // PLL Enable (4x PLL disabled)
#pragma config STVREN = OFF     // Stack Overflow/Underflow Reset Enable (Stack Overflow or Underflow will not cause a Reset)
#pragma config BORV = LO        // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (Vbor), low trip point selected.)
#pragma config LPBOREN = OFF    // Low Power Brown-out Reset enable bit (LPBOR is disabled)
#pragma config LVP = OFF        // Low-Voltage Programming Enable (High-voltage on MCLR/VPP must be used for programming)
#define _XTAL_FREQ 16000000L
#include <xc.h>
#include "12f1572.h"
void main(void) {
    //osccon register
    SPLLEN=0;
    OSCCONbits.IRCF = 0b0111;
    SCS0=0;
    SCS1=1;
     //oscstat register
   PLLR=0;
   OSTS=0;
   HFIOFR=1;
   HFIOFL=0;
   MFIOFR=0;
   LFIOFR=0;
   HFIOFS=0;
    TRISA=0x00;
    PORTA=0x00;
    while(1){
        RA4=1;
        __delay_ms(500);
      RA4=0;
Mod edit: code tags
JohnInTX
Joined Jun 26, 2012
4,787
You need another delay after RA4=0;
Edit:
You also have to make RA4 a digital port by writing 0 to ANSELA bit 4.
Finally, be sure that writing RA4 uses the LATA register, not PORTA - look at the disassembly listing or check the compiler manual or header file to be sure. I don't recall right off if it uses LATx automatically or you have to specify it explicitly. Single bit writes to PORTx can be problematic.
Edit 2: I took a look at the .h file for you and RA4 does indeed reference PORTA. You want to use LATA4 instead of RA4:
C:
LATA4 = 1;
delay..
LATA4 = 0;
delay..
dandrous
Joined Mar 2, 2015
22
hi i gets error while using delay function in pic18f2220
here is the error message,
"C:\Program Files (x86)\Microchip\xc8\v1.38\bin\xc8.exe" --pass1 --chip=18F2220 -Q -G --double=24 --float=24 --emi=wordwrite --opt=default,+asm,+asmfile,-speed,+space,-debug --addrqual=ignore --mode=free -P -N255 --warn=-3 --asmlist -DXPRJ_default=default --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,-download,+config,+clib,-plib --output=-mcof,+elf:multilocs --stack=compiled:auto:auto:auto "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" -obuild/default/production/newmain.p1 newmain.c
newmain.c:21: error: (195) expression syntax
newmain.c:21: error: (187) too few function arguments
newmain.c:21: error: (194) ")" expected
(908) exit status = 1
nbproject/Makefile-default.mk:100: recipe for target 'build/default/production/newmain.p1' failed
make[2]: Leaving directory 'C:/Users/dandrous/MPLABXProjects/test.X'
nbproject/Makefile-default.mk:84: recipe for target '.build-conf' failed
make[1]: Leaving directory 'C:/Users/dandrous/MPLABXProjects/test.X'
nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
make[2]: *** [build/default/production/newmain.p1] Error 1
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
BUILD FAILED (exit value 2, total time: 1s)
Code:
//////////////header file
#pragma config OSC = INTIO2     // Oscillator Selection bits (Internal RC oscillator, port function on RA6 and port function on RA7)
#pragma config FSCM = ON        // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor enabled)
#pragma config IESO = OFF       // Internal/External Switchover bit (Internal/External Switchover mode disabled)
// CONFIG2L
#pragma config PWRT = OFF       // Power-up Timer enable bit (PWRT disabled)
#pragma config BOR = OFF        // Brown-out Reset enable bit (Brown-out Reset disabled)
#pragma config BORV = 20        // Brown-out Reset Voltage bits (VBOR set to 2.0V)
// CONFIG2H
#pragma config WDT = OFF         // Watchdog Timer Enable bit (WDT enabled)
#pragma config WDTPS = 32768    // Watchdog Timer Postscale Select bits (1:32768)
// CONFIG3H
#pragma config CCP2MX = ON      // CCP2 MUX bit (CCP2 input/output is multiplexed with RC1)
#pragma config PBAD = ANA       // PORTB A/D Enable bit (PORTB<4:0> pins are configured as analog input channels on Reset)
#pragma config MCLRE = ON       // MCLR Pin Enable bit (MCLR pin enabled; RE3 input pin disabled)
// CONFIG4L
#pragma config STVR = ON        // Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
#pragma config LVP = ON         // Single-Supply ICSP Enable bit (Single-Supply ICSP enabled)
// CONFIG5L
#pragma config CP0 = OFF        // Code Protection bit (Block 0 (000200-0007FFh) not code-protected)
#pragma config CP1 = OFF        // Code Protection bit (Block 1 (000800-000FFFh) not code-protected)
// CONFIG5H
#pragma config CPB = OFF        // Boot Block Code Protection bit (Boot block (000000-0001FFh) is not code-protected)
#pragma config CPD = OFF        // Data EEPROM Code Protection bit (Data EEPROM is not code-protected)
// CONFIG6L
#pragma config WRT0 = OFF       // Write Protection bit (Block 0 (000200-0007FFh) not write-protected)
#pragma config WRT1 = OFF       // Write Protection bit (Block 1 (000800-000FFFh) not write-protected)
// CONFIG6H
#pragma config WRTC = OFF       // Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) are not write-protected)
#pragma config WRTB = OFF       // Boot Block Write Protection bit (Boot block (000000-0001FFh) is not write-protected)
#pragma config WRTD = OFF       // Data EEPROM Write Protection bit (Data EEPROM is not write-protected)
// CONFIG7L
#pragma config EBTR0 = OFF      // Table Read Protection bit (Block 0 (000200-0007FFh) not protected from table reads executed in other blocks)
#pragma config EBTR1 = OFF      // Table Read Protection bit (Block 1 (000800-000FFFh) not protected from table reads executed in other blocks)
// CONFIG7H
#pragma config EBTRB = OFF      // Boot Block Table Read Protection bit (Boot block (000000-0001FFh) is not protected from table reads executed in other blocks)
#include <xc.h>
#define _XTAL_FREQ=8000000
/////main c
#include <stdio.h>
#include <stdlib.h>
#include "newfile.h"
void main(void) {
    TRISAbits.RA0=0;
    OSCCON=0x76;
    while(1)
        LATBbits.LATB0=0;
        __delay_ms(50);
          LATBbits.LATB0=1;
TQFP44
Joined Sep 3, 2016
51
I have the dsPIC33EV256GM104 chip on a breakout board, but not done any PWM with it , should be some examples out there... as a starting place, (super mcu )
