pic/ mikro c question
dayv3
Joined May 22, 2014
38
Just a quick question, I am writing a program for a 16F636 and I wanted to know how large of a number I can count up to
using an unsigned int in mikro c. I wrote an interrupt routine, timer 0, to over flow at about every 1ms. I then used an
unsigned int to count the number of times the counter over flows to make decisions on. I need to count up to about
3 seconds, 3000ms, of over flows. But I am concerned about how large a variable can be since it is a 8 bit processor.
Does the compiler take care of it or do I need to? Do I need to use timer1?
Dave
Picbuster
Joined Dec 2, 2013
1,062
this information is in the C micro compiler manual.
@ microchip xc8 it's 16 bits.
Personal question why prefer micro C above XC8 ?
Picbuster
Ian Rogers
Joined Dec 12, 2012
1,136
I have always hated the old "int" variable in C An int is an integer and was 8 bit on the old machines..
byte, word and double word... Or Long and long long are more fitting..
If you use unsigned long then you have a integer value up to 4GIG and yes, you can count that high..
Regarding timers... You can buffer the timer overflow and each spill increment a software timer.. This way you can use timer0 and have any length precision you want..
spinnaker
Joined Oct 29, 2009
7,830
Dave
Took me about 2 minutes to figure it out and I don't even use mikro C.
http://download.mikroe.com/documents/compilers/mikroc/pic/help/arithmetic_types.htm
Actually it took me longer to post this.
dayv3
Joined May 22, 2014
38
Thank you for all that helped.
@Picbuster - I was undecided on which one to buy then one day, when I was deciding, I logged onto
the mikroc web site and because it was the day of their 10th anniversary and they had the compiler on sale for $100.
