MIKRO C pic18f2550 read but not write variable data !?
Hassan Abu al rub
Joined Feb 10, 2019
11
am using pic18f2550 (full code in attachment)
successful read data to controll pwm brightness
but i need to (write) data from mcu ( send from mikrocontroller ) but not working
i try this code but not working
when portb fo pressed counter will increase and send value from mcu this is all
if (portb.f0==0){ counter++; }
sprintf(write_buffer,"senddata=") ;
strcpy(process, strtok(write_buffer, "="));
strcpy(process, strtok(0, "s"));
counter=atoi(process);
while(!HID_Write(&write_buffer,64)) ;
_____________________________________________
code : file available also
_________________________________________________________________________
char read_buffer[64] absolute 0x500;
char write_buffer[64] absolute 0x540;
char process[30];
char dato=0;
char incvalue=0;
char cuenta=0;
char kk;
char state1;
int counter=0;
int i = 0;
void interrupt()
usb_interrupt_proc();
void main() {
OSCCON = 0b01001110;
INTCON.GIE = 1;
INTCON.TMR0IE = 1;
T0CON = 0x82;
trisb.f0=1;
HID_Enable(&read_buffer,&write_buffer);
PWM1_Init(3000);
PWM1_Set_Duty(0);
PWM1_Start();
read_buffer[cuenta]=dato;
while(1)
kk = HID_Read();
if (kk != 0) {
cuenta++;
if (cuenta>=30)
cuenta=0;
if ( strstr(read_buffer,"M1pwm=" ))
strcpy(process, strtok(read_buffer, "="));
strcpy(process, strtok(0, "M"));
dato=atoi(process);
PWM1_Set_Duty(dato);
memset(read_buffer,0,30);
cuenta=0;
