PIC microcontroller debugging- dspic33ch128mp508
chaminda12001
Joined May 9, 2019
Hi ,
I am getting error message when I go to debugging dspic33ch128mp508 curiorsity development board. I inculded the configuration settings at the begining of the programme. error message : "Target Device Not Ready For Debugging Check Config Bits PGC, PGD Settings". Is there settings I need to check
C:
// FSEC
#pragma config BWRP = OFF               // Boot Segment Write-Protect bit (Boot Segment may be written)
#pragma config BSS = DISABLED           // Boot Segment Code-Protect Level bits (No Protection (other than BWRP))
#pragma config BSEN = OFF               // Boot Segment Control bit (No Boot Segment)
#pragma config GWRP = OFF               // General Segment Write-Protect bit (General Segment may be written)
#pragma config GSS = DISABLED           // General Segment Code-Protect Level bits (No Protection (other than GWRP))
#pragma config CWRP = OFF               // Configuration Segment Write-Protect bit (Configuration Segment may be written)
#pragma config CSS = DISABLED           // Configuration Segment Code-Protect Level bits (No Protection (other than CWRP))
#pragma config AIVTDIS = OFF            // Alternate Interrupt Vector Table bit (Disabled AIVT)
// FBSLIM
#pragma config BSLIM = 0x1FFF           // Boot Segment Flash Page Address Limit bits (Enter Hexadecimal value)
// FOSCSEL
#pragma config FNOSC = FRC          // Oscillator Source Selection (Internal Fast RC (FRC) Oscillator with postscaler)
#pragma config IESO = ON                // Two-speed Oscillator Start-up Enable bit (Start up device with FRC, then switch to user-selected oscillator source)
// FOSC
#pragma config POSCMD = NONE            // Primary Oscillator Mode Select bits (Primary Oscillator disabled)
#pragma config OSCIOFNC = OFF           // OSC2 Pin Function bit (OSC2 is clock output)
#pragma config FCKSM = CSECMD           // Clock Switching Mode bits (Clock switching is enabled,Fail-safe Clock Monitor is disabled)
#pragma config PLLKEN = PLLKEN_ON       // PLLKEN (PLLKEN_ON)
#pragma config XTCFG = G3               // XT Config (24-32 MHz crystals)
#pragma config XTBST = ENABLE           // XT Boost (Boost the kick-start)
// FWDT
#pragma config RWDTPS = PS1048576       // Run Mode Watchdog Timer Post Scaler select bits (1:1048576)
#pragma config RCLKSEL = LPRC           // Watchdog Timer Clock Select bits (Always use LPRC)
#pragma config WINDIS = OFF             // Watchdog Timer Window Enable bit (Watchdog Timer operates in Window mode)
#pragma config WDTWIN = WIN25           // Watchdog Timer Window Select bits (WDT Window is 25% of WDT period)
#pragma config SWDTPS = PS1048576       // Sleep Mode Watchdog Timer Post Scaler select bits (1:1048576)
#pragma config FWDTEN = ON_SW             // Watchdog Timer Enable bit (WDT enabled in hardware)
// FICD
#pragma config ICS = PGD3               // ICD Communication Channel Select bits (Communicate on PGC1 and PGD1)
#pragma config JTAGEN = OFF             // JTAG Enable bit (JTAG is disabled)
// FDMT
#pragma config DMTDIS = OFF             // Dead Man Timer Disable bit (Dead Man Timer is Disabled and can be enabled by software)
// FS1OSCSEL
#pragma config S1FNOSC = FRC        // Oscillator Source Selection (Internal Fast RC (FRC) Oscillator with postscaler)
#pragma config S1IESO = ON              // Two-speed Oscillator Start-up Enable bit (Start up device with FRC, then switch to user-selected oscillator source)
// FS1OSC
#pragma config S1OSCIOFNC = OFF         // Slave OSC2 Pin Function bit (OSC2 is clock output)
#pragma config S1FCKSM = CSDCMD         // Clock Switching Mode bits (Both Clock switching and Fail-safe Clock Monitor are disabled)
#pragma config S1PLLKEN = S1PLLKEN_ON   // S1PLLKEN (S1PLLKEN_ON)
// FS1WDT
#pragma config S1RWDTPS = PS1048576     // Run Mode Watchdog Timer Post Scaler select bits (1:1048576)
#pragma config S1RCLKSEL = LPRC         // Watchdog Timer Clock Select bits (Always use LPRC)
#pragma config S1WINDIS = ON            // Watchdog Timer Window Enable bit (Watchdog Timer operates in Non-Window mode)
#pragma config S1WDTWIN = WIN25         // Watchdog Timer Window Select bits (WDT Window is 25% of WDT period)
#pragma config S1SWDTPS = PS1048576     // Sleep Mode Watchdog Timer Post Scaler select bits (1:1048576)
#pragma config S1FWDTEN = ON_SW            // Watchdog Timer Enable bit (WDT enabled in hardware)
// FS1ICD
#pragma config S1ICS = PGD3             // ICD Communication Channel Select bits (Communicate on PGC1 and PGD1)
#pragma config S1ISOLAT = ON            // Isolate the Slave core subsystem from the master subsystem during Debug (The slave can operate (in debug mode) even if the SLVEN bit in the MSI is zero.)
#pragma config S1NOBTSWP = OFF          // BOOTSWP Instruction Enable/Disable bit (BOOTSWP instruction is disabled)
Mod edit: code tags
