PIC Development Board with PK3
Djsarakar
Joined Jul 26, 2020
489
Make sense?
Can you expand your code a bit that show two routine, one main routine and one interrupt service routine?
maybe get some idea
C:
unsigned char counter;
bit BUTTON_x;
if input == FALSE{
  counter = 0;  // button is open, reset everything
  BUTTON_x = FALSE;
else{  // input is true, debounce if necessary
   if(BUTTON_x == FALSE){  // if button closed but not fully debounced yet
     counter++;
     if(counter == DEBOUNCE_TIKS)
        BUTTON_x = TRUE;    // fully debounced
    } // else, button TRUE and is already debounced, nothing to do
} // input is true
Edit : When switch button is pressed or released, both times the switch bounces. I don't see debounce logic when button release in your code
Which line in the code check the switch whether it is open or closed?
trebla
Joined Jun 29, 2019
599
Let the interrupt routine set the flag as it works already and concentrate on the button routine.
In this button routine:
1. check the flag, if set clear it and check status variable (you must define it at beginning):
a) if status is idle (button not pressed awhile) check button input - if pressed change status to detected, if not, jump out of this routine
b) if status is detected increase debounce counter by one and check it is reached to 20 - if it is, change status to debounced, clear debounce counter and jump out of this routine, if not reached 20, just jump out of this routine
c) if status is debounced, check button input - if still pressed, just jump out of this routine, if released change status to released and increase debounce counter by one and check it is reached to 20 - if it is, change status to idle, clear debounce counter and jump out of this routine, if not reached 20, just jump out of this routine
2. you can send messages to rest of your program by setting different flags if, for example, you are setting status to "detected", then some another function receiving this flag is responsible to clear this flag.
Just let interrupt set the flag and the button routine will act every time it find the flag set depending the status variable
You can set up status names by:
#define IDLE 0
#define DETECTED 1
...etc
or by :
enum debounce { IDLE, DETECTED, ...etc }; // define constants
enum debounce status = IDLE; //declare status variable and initialize to IDLE
JohnInTX
Joined Jun 26, 2012
4,787
*exhales*
C-like:
bit BUTTON_x;
bit Interrupt_Flag_1ms;
interrupt()
  if(TMR1IF == 1){
    TMR1IF = 0;
    reload the timer;
    Interrupt_Flag_1ms = 1;  // set flag to indicate 1ms has elapsed
  ... process any other interrrupts
// Switch input/debounce support function
// Samples switch input on each call
// If switch is stays continuously TRUE for DEBOUCE_TIKS, set the BUTTON_x flag
// else clear BUTTON_x flag
void Run_Debounce(void){
if input == FALSE{    <<<<<<<<<<<<<<<<<< SAMPLE THE SWITCH INPUT,
   BUTTON_x = FALSE;
      counter++;
} // input is true
void main(void){
  do the init stuff, set up the timer etc.
  if (Interrupt_Flag_1ms == 1){  // if 1ms has elapsed, process the switch input(s), updates BUTTON_x flag
    Interrupt_Flag_1ms = 0;  // clear the flag for next time
    Run_Debounce();        // process switch
   then do_other_stuff();
  // use the clean debounced button for something
   if(BUTTON_x == 1)
     LED_ON;
   else
     LED_OFF;
The debouncer only debounces on pressing the button. It does not debounce the release. That's OK for now.
Djsarakar
Joined Jul 26, 2020
489
I was doing research to understand switch debouncing , then I came across an old thread and saw your reply #3 with code
https://forum.allaboutcircuits.com/threads/debouncing-a-switch-in-software-using-a-pic16f72.100339/
The switch is debounced both ways.
what was the meaning of above sentence
It appears that in the code you increment the counter if the switch is closed and decrement the counter if the switch is open
Sorry for asking about the reply of old thread but clarification was required
Edit :
C-like:
   BUTTON_x = FALSE;
What is input in your code?
You are checking input directly but you haven't used it anywhere before in code
JohnInTX
Joined Jun 26, 2012
4,787
Debouncing both ways means that it not only debounces when the switch is pressed but for when it is released. There are reasons to do that but not here. The task is debouncing without blocking code. Let's stick to that.
This is pseudo-code, it is not meant to be complete or to compile without errors. I am just trying to get you to see the logic behind:
1) passing a flag out of an interrupt routine at 1ms intervals
2) doing the debounce action at 1ms intervals when the flag gets set by the interrupt routine. Clear the flag and process the debounce.
3) understanding ONE way of debouncing a switch.
READ the code and figure out its logic. Use a pencil and paper or write a flow chart from the pseudo-code. You can't proceed until you understand the logic of how this particular debouncer works.
Of those 3 items, which do you not understand?
The input is your button. It is TRUE when the button is pressed and FALSE when the button is released. You need to connect a button to an input port and determine what logic level is TRUE and what level is FALSE.
Djsarakar
Joined Jul 26, 2020
489
I've compiled and ran following code. When I press button LED is not turning ON but It supposed to turn ON It seems logic error in code
C:
#define _XTAL_FREQ 8000000
#include <xc.h>
// PIC18F45K80 Configuration Bit Settings
// 'C' source line config statements
// CONFIG1L
#pragma config RETEN = OFF      // VREG Sleep Enable bit (Ultra low-power regulator is Disabled (Controlled by REGSLP bit))
#pragma config INTOSCSEL = HIGH // LF-INTOSC Low-power Enable bit (LF-INTOSC in High-power mode during Sleep)
#pragma config SOSCSEL = HIGH   // SOSC Power Selection and mode Configuration bits (High Power SOSC circuit selected)
#pragma config XINST = OFF       // Extended Instruction Set (Enabled)
// CONFIG1H
#pragma config FOSC = INTIO2    // Oscillator (Internal RC oscillator)
#pragma config PLLCFG = OFF     // PLL x4 Enable bit (Disabled)
#pragma config FCMEN = OFF      // Fail-Safe Clock Monitor (Disabled)
#pragma config IESO = OFF       // Internal External Oscillator Switch Over Mode (Disabled)
// CONFIG2L
#pragma config PWRTEN = OFF     // Power Up Timer (Disabled)
#pragma config BOREN = SBORDIS  // Brown Out Detect (Enabled in hardware, SBOREN disabled)
#pragma config BORV = 3         // Brown-out Reset Voltage bits (1.8V)
#pragma config BORPWR = ZPBORMV // BORMV Power level (ZPBORMV instead of BORMV is selected)
// CONFIG2H
#pragma config WDTEN = OFF      // Watchdog Timer (WDT disabled in hardware; SWDTEN bit disabled)
#pragma config WDTPS = 1048576  // Watchdog Postscaler (1:1048576)
// CONFIG3H
#pragma config CANMX = PORTB    // ECAN Mux bit (ECAN TX and RX pins are located on RB2 and RB3, respectively)
#pragma config MSSPMSK = MSK7   // MSSP address masking (7 Bit address masking mode)
#pragma config MCLRE = ON       // Master Clear Enable (MCLR Enabled, RE3 Disabled)
// CONFIG4L
#pragma config STVREN = ON      // Stack Overflow Reset (Enabled)
#pragma config BBSIZ = BB2K     // Boot Block Size (2K word Boot Block size)
// CONFIG5L
#pragma config CP0 = OFF        // Code Protect 00800-01FFF (Disabled)
#pragma config CP1 = OFF        // Code Protect 02000-03FFF (Disabled)
#pragma config CP2 = OFF        // Code Protect 04000-05FFF (Disabled)
#pragma config CP3 = OFF        // Code Protect 06000-07FFF (Disabled)
// CONFIG5H
#pragma config CPB = OFF        // Code Protect Boot (Disabled)
#pragma config CPD = OFF        // Data EE Read Protect (Disabled)
// CONFIG6L
#pragma config WRT0 = OFF       // Table Write Protect 00800-01FFF (Disabled)
#pragma config WRT1 = OFF       // Table Write Protect 02000-03FFF (Disabled)
#pragma config WRT2 = OFF       // Table Write Protect 04000-05FFF (Disabled)
#pragma config WRT3 = OFF       // Table Write Protect 06000-07FFF (Disabled)
// CONFIG6H
#pragma config WRTC = OFF       // Config. Write Protect (Disabled)
#pragma config WRTB = OFF       // Table Write Protect Boot (Disabled)
#pragma config WRTD = OFF       // Data EE Write Protect (Disabled)
// CONFIG7L
#pragma config EBTR0 = OFF      // Table Read Protect 00800-01FFF (Disabled)
#pragma config EBTR1 = OFF      // Table Read Protect 02000-03FFF (Disabled)
#pragma config EBTR2 = OFF      // Table Read Protect 04000-05FFF (Disabled)
#pragma config EBTR3 = OFF      // Table Read Protect 06000-07FFF (Disabled)
// CONFIG7H
#pragma config EBTRB = OFF      // Table Read Protect Boot (Disabled)
__bit BUTTON_x;
__bit Interrupt_Flag_1ms;
#define Button          PORTBbits.RB0
#define LED             LATDbits.LATD2
#define DEBOUNCE_TIKS  10
void Port_Initialized (void);
void Timer0_Initialized (void);
void __interrupt(high_priority) tcInt(void);
    // LATx registers
    LATA =  0x00;
    LATB =  0x00;
    LATC =  0x00;
    LATD =  0x00;
    LATE =  0x00;
//  TRISx registers
    TRISA = 0x00;      // All are output, Unused
    TRISB = 0x80;      // Button connected to RB0
    TRISC = 0x00;      // all are output, Unused
    TRISD = 0x00;      // LED connected to RD2 pin
    TRISE = 0x00;      // All are output, Unused
    ANCON0 = 0x00;     // set to digital port
    ANCON1 = 0x00;     // Set to digital port
    CM1CON = 0x00;     // Comparator off
    CM2CON = 0x00;     // Comparator off
    ADCON0 = 0x00;     // A/D conversion Disabled
    ADCON1 = 0x00;     // A/D conversion Disabled
    ADCON2 = 0x00;     // A/D conversion Disabled
     TMR0L = 250;    //Timer0 Register Low Byte
    //T0CON: TIMER0 CONTROL REGISTER
     TMR0ON = 1; //Timer0 On
     T08BIT = 1; // Timer0 is configured as an 8-bit timer/counter0
     T0CS = 0;   // Internal instruction cycle clock (CLKO)
     T0SE = 1;    //Increments on high-to-low transition on T0CKI pin0
     PSA = 0; //Timer0 prescaler is assigned; Timer0 clock input comes from prescaler output
     //1:8 Prescale value
     T0PS2 = 1;
     T0PS1 = 1;
     T0PS0 = 1;
     //INTCON: INTERRUPT CONTROL
     PEIE = 0;   //Disables all peripheral interrupts
     TMR0IE = 1; //Enables the TMR0 overflow interrupt
     INT0IE = 0; //Disables the INT0 external interrupt
     RBIE = 0; //Disables the RB port change interrupt
     TMR0IF = 0;// cleared timer overflow flag
     INT0IF = 0; // disabled external interrupt
     RBIF = 0; //disabled Port Change Interrupt Flag bit
     GIE = 1;    // Enable Global Interrupt Enable bit
  if (Button == 0)
    BUTTON_x = 0;
  else
    if(BUTTON_x == 0)
      counter++;
        BUTTON_x = 1;    // fully debounced
void main(void)
    Port_Initialized ();
    Timer0_Initialized ();
    while (1)
        if(BUTTON_x == 1)
            LED = 1;
        else
            LED = 0;
  if (TMR0IF == 1) // Timer0 overflow interrupt flag bit
      TMR0IF = 0;
Djsarakar
Joined Jul 26, 2020
489
OK.. so debug it.
Where would you start?
I set breakpoint on line 149. When cursor is on line 145 I click F7 then cursor stop at line 152 but I don't understand doesn't code go through line 147, 148
Edit : there is no problem in ISR routine I've debug it
JohnInTX
Joined Jun 26, 2012
4,787
That's probably because when you run it after the breakpoint the timer has not yet generated another interrupt and flag.
If you have confirmed the interrupt occurs at 1ms intervals with the stopwatch, clear that breakpoint and put two new ones in Run_Debounce() (post #446). Click RUN after each breakpoint.
It should break on line 123 when the button is open.
It should break on line 130 when the button is pressed.
Does it?
Djsarakar
Joined Jul 26, 2020
489
Does it?
yes It happens
When the button is open.
When the button is pressed.
JohnInTX
Joined Jun 26, 2012
4,787
It looks like it is reading the button.
Does it break at line 132 after 10 passes with the button pushed?
I assume you fixed the TRISB init problem present in #446.
JohnInTX
Joined Jun 26, 2012
4,787
fixed it TRISB = 0xFF; #446
I'm not sure how you got to the two breakpoints in #450 but yes, the port needs to be an input.
I'm not clear On which line do I have to set breakpoint ?
Read the Run_Debounce() function. When the button is closed it counts once time the routine is called up to 10 then sets a flag. Set a breakpoint to confirm that action.
When should I run program ? Do I have to hold button or press it once
In Run_Debounce() ?? Try it and see where the code goes. There are 3 conditions possible in Run_Debounce():
Button not held
Button held and counter counting up each time the function is called
Button held and counter has finished counting to 10 - flag is set.
Set the a breakpoint in each section to confirm the three actions. Once all are working, the BUTTON_x flag will follow the debounced button input.
EDIT: Your button input is a logic '1' when open and a logic '0' when pressed according to the schematic. Does that work with this line?
if (Button == 0) // if button is NOT pressed...
A good exercise at this point would be to fully comment the code in Run_Debounce() so that you know how it should work.
Djsarakar
Joined Jul 26, 2020
489
@JohnInTX
i have found the solution after many attempts. So the cable between the microcontroller and push button was bad. I replaced the bad cable with a new cable.
Now When I press the button, LED goes turns on and when I release the button, LED goes turns off
C:
#include <xc.h>
// CONFIG1L
// CONFIG1H
// CONFIG2L
// CONFIG2H
// CONFIG3H
// CONFIG4L
// CONFIG5L
// CONFIG5H
// CONFIG6L
// CONFIG6H
// CONFIG7L
// CONFIG7H
__bit BUTTON_x;
    // LATx registers
    LATA =  0x00;
    LATB =  0x00;
    LATC =  0x00;
    LATD =  0x00;
    LATE =  0x00;
//  TRISx registers
     T0PS2 = 1;
     T0PS1 = 1;
     T0PS0 = 1;
  if (Button == 0)
    BUTTON_x = 0;
  else
    if(BUTTON_x == 0)
      counter++;
void main(void)
    while (1)
        if(BUTTON_x == 1)
            LED = 1;
        else
            LED = 0;
      TMR0IF = 0;
I was correct, sequence goes from left to right in increasing order
0x80 = 0b10000000 = RB0, RB1, RB2, RB3, RB4,RB5, RB6, and RB7
It show portB pin RB0 become input pin all other are output pins
JohnInTX
Joined Jun 26, 2012
4,787
It's a good idea to test the hardware by measuring the voltage at the PIC pin as you push and release the button.
That is not the way the port bits are ordered. See table 11-4 in the datasheet. Left to right is RB7->RB0.
Did you step through the debounce routine to make sure it is actually doing the counting and correctly sensing the button?
When that is sorted, a couple of good exercises would be:
1) How would you make the button a toggle? Press once to turn the LED on continuously. Press again to turn the LED off.
2) How would you count the number of times that the button has been pressed.? One press and release is one count.
Djsarakar
Joined Jul 26, 2020
489
I have debugged code. It's counting and correctly sensing the button
I have finished first task. Press once to turn the LED on continuously. Press again to turn the LED off.
C:
#include <xc.h>
// CONFIG1L
// CONFIG1H
// CONFIG2L
// CONFIG2H
// CONFIG3H
// CONFIG4L
// CONFIG5L
// CONFIG5H
// CONFIG6L
// CONFIG6H
// CONFIG7L
// CONFIG7H
__bit BUTTON_x;
    // LATx registers
    LATA =  0x00;
    LATB =  0x00;
    LATC =  0x00;
    LATD =  0x00;
    LATE =  0x00;
//  TRISx registers
    TRISB = 0b00000001;      // Button connected to RB0
     T0PS2 = 1;
     T0PS1 = 1;
     T0PS0 = 1;
  if (Button == 0)
    BUTTON_x = 0;
  else
    if(BUTTON_x == 0)
      counter++;
void main(void)
    while (1)
        if(BUTTON_x == 1)
            LED =~ LED;
Djsarakar
Joined Jul 26, 2020
489
Does it work reliably?
something is going wrong. I don't see any problem with logic
if(BUTTON_x == 1) // check state every time
LED ~= LED; // change LED state
I tried to trace the logic problem in the code but don't know where exactly the problem is happening. Can you point out where exactly the problem is occurring?
