What's wrong with this32768.0 would be the way to specify that value.
I would keep ADC_Result an integer while combining bytes (line 28) then cast it to a float for the arithmetic:
Result_V = ( ((float) ADC_Result) / 32768.0) * 2.048); // or something like that
int ADC_Result;
float Result_V;
void main(void)
unsigned char i = 0;
unsigned char Data1 [10]="Test";
Port_Initialized ();
LCD_Initialized();
I2C_Initialized();
// Write to Config register
Result1 = Write_I2C_Device(SLAVE_ADDRESS , Word_Address , sizeof(ADS1115_data), ADS1115_data);
__delay_ms(10);
while(1)
Result3 = Read_I2C_Device(SLAVE_ADDRESS, 0x00 , 2, rd_buf) ;
__delay_ms(10);
asm("nop");
if(Result3 == 0) // if successful read..
ADC_Result = (rd_buf[0] << 8) + rd_buf[1];
Result_V = ((float)(ADC_Result /32768.0) * 2.048);
sprintf( (char *) A_buffer,"ADC value: %f", Result_V );
WriteCommand(0x80); //// Move the cursor to beginning of first line.
LCD_Data(A_buffer);
no warnings but I don't know why program doesn't reach at last line 334Line 27: Result_V = ( (float) (ADC_Result /32768.0) * 2.048);
Your parenthesis are in the wrong place. The parentheses you have are first dividing an integer by a float then casting the result to float then multiplying. You want to cast ADC_Result to a float first before other calculations. It may be easier to see if you split it up:
Result_V = (float)ADC_Result;
Result_V /= 32768.0;
Result_V *= 2.048;
#define _XTAL_FREQ 20000000 // crystal 20MHz
// PIC18F45K80 Configuration Bit Settings
// CONFIG1L
#pragma config RETEN = ON // VREG Sleep Enable bit (Ultra low-power regulator is Enabled (Controlled by SRETEN bit))
#pragma config INTOSCSEL = LOW // LF-INTOSC Low-power Enable bit (LF-INTOSC in Low-power mode during Sleep)
// SOSCSEL = No Setting
#pragma config XINST = OFF // Extended Instruction Set (Disabled)
// CONFIG1H
#pragma config FOSC = HS2 // HS oscillator (high power, 16 MHz-25 MHz
#pragma config PLLCFG = OFF // PLL x4 Enable bit (Disabled)
#pragma config FCMEN = OFF // Fail-Safe Clock Monitor (Disabled)
#pragma config IESO = OFF // Internal External Oscillator Switch Over Mode (Disabled)
// CONFIG2L
#pragma config PWRTEN = ON // Power Up Timer (Enabled)
#pragma config BOREN = OFF // Brown Out Detect (Disabled in hardware, SBOREN disabled)
#pragma config BORV = 0 // Brown-out Reset Voltage bits (3.0V)
#pragma config BORPWR = LOW // BORMV Power level (BORMV set to low power level)
// CONFIG2H
#pragma config WDTEN = OFF // Watchdog Timer (WDT disabled in hardware; SWDTEN bit disabled)
#pragma config WDTPS = 1 // Watchdog Postscaler (1:1)
// CONFIG3H
#pragma config CANMX = PORTC // ECAN Mux bit (ECAN TX and RX pins are located on RC6 and RC7, respectively)
#pragma config MSSPMSK = MSK5 // MSSP address masking (5 bit address masking mode)
#pragma config MCLRE = ON // Master Clear Enable (MCLR Enabled, RE3 Disabled)
// CONFIG4L
#pragma config STVREN = OFF // Stack Overflow Reset (Disabled)
#pragma config BBSIZ = BB1K // Boot Block Size (1K word Boot Block size)
// CONFIG5L
#pragma config CP0 = ON // Code Protect 00800-01FFF (Enabled)
#pragma config CP1 = ON // Code Protect 02000-03FFF (Enabled)
#pragma config CP2 = ON // Code Protect 04000-05FFF (Enabled)
#pragma config CP3 = ON // Code Protect 06000-07FFF (Enabled)
// CONFIG5H
#pragma config CPB = ON // Code Protect Boot (Enabled)
#pragma config CPD = ON // Data EE Read Protect (Enabled)
// CONFIG6L
#pragma config WRT0 = ON // Table Write Protect 00800-01FFF (Enabled)
#pragma config WRT1 = ON // Table Write Protect 02000-03FFF (Enabled)
#pragma config WRT2 = ON // Table Write Protect 04000-05FFF (Enabled)
#pragma config WRT3 = ON // Table Write Protect 06000-07FFF (Enabled)
// CONFIG6H
#pragma config WRTC = ON // Config. Write Protect (Enabled)
#pragma config WRTB = ON // Table Write Protect Boot (Enabled)
#pragma config WRTD = ON // Data EE Write Protect (Enabled)
// CONFIG7L
#pragma config EBTR0 = ON // Table Read Protect 00800-01FFF (Enabled)
#pragma config EBTR1 = ON // Table Read Protect 02000-03FFF (Enabled)
#pragma config EBTR2 = ON // Table Read Protect 04000-05FFF (Enabled)
#pragma config EBTR3 = ON // Table Read Protect 06000-07FFF (Enabled)
// CONFIG7H
#pragma config EBTRB = ON // Table Read Protect Boot (Enabled)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#pragma warning disable 520
#include <xc.h>
#include <stdio.h>
#include <conio.h>
unsigned char Result1;
unsigned char Result2;
volatile unsigned char Result3;
unsigned char Result4;
// The code should set the R/W bit according to its function
#define SLAVE_ADDRESS 0x90 //I2C slave address of ADS1115 (8 bit format)
#define Word_Address 0x01 // Points to Config register
#define LCD_RS LATBbits.LATB4
#define LCD_TRIS_RS TRISBbits.TRISB4
#define LCD_RW LATBbits.LATB5
#define LCD_TRIS_RW TRISBbits.TRISB5
#define LCD_E LATBbits.LATB6
#define LCD_TRIS_E TRISBbits.TRISB6
#define LCDPORT LATD
#define LCDTRISD LATD
void Port_Initialized (void);
void WriteNibble(unsigned char command);
void WaitLCDBusy(void);
void WriteCommand(unsigned char command);
// LATx registers
LATA = 0x00;
LATB = 0x00;
LATC = 0x00;
LATD = 0x00;
LATE = 0x00;
// TRISx registers
TRISA = 0x00; // All are output, Unused
TRISB = 0x00; // all are output, Unused
TRISC = 0x18; // Slave SDA and CLOCK
TRISD = 0x00; // LCD
TRISE = 0x00; // All are output, Unused
ANCON0 = 0x00; // set to digital port
ANCON1 = 0x00; // Set to digital port
CM1CON = 0x00; // Comparator off
CM2CON = 0x00; // Comparator off
ADCON0 = 0x00; // A/D conversion Disabled
ADCON1 = 0x00; // A/D conversion Disabled
ADCON2 = 0x00; // A/D conversion Disabled
// Wait for 5 ms
__delay_ms(5);
//Send a command to the LCD
WaitLCDBusy(); //wait until not busy
LCD_RS = 0; //setup to send command
WriteNibble(command); //write the high nibble
WriteNibble( (unsigned char)(command<<4) ); //then the low nibble
//Initialized LCD
void LCD_Initialized()
LCDTRISD &=0x0f; //ensure data bits are output
LCD_E=0; //clear enable
LCD_RS = 0; //going to write command
LCD_TRIS_E=0; //Set enable to output
LCD_TRIS_RS=0; //set RS to output
LCD_TRIS_RW=0;
LCD_RW=0;
__delay_ms(30); //delay for LCD to initialize.
WriteNibble(0x30); //Required for initialization
__delay_ms(5); //required delay
__delay_ms(1); //required delay
WriteCommand(0x20); //set to 4 bit interface
WriteCommand(0x2c); //set to 4 bit interface, 2 line and 5*10 font
WriteCommand(0x06); //move cursor right after write
WriteCommand(0x0C); //turn on display
WriteCommand(0x01); //clear display
//Send a character to the LCD
void WriteChar(unsigned char chr)
LCD_RS=1; //Setup to send character
WriteNibble(chr); //write the high nibble
WriteNibble( (unsigned char)(chr<<4)); //then the low nibble
//Send any 4 bits to the LCD
LCDPORT &= 0x0f; //clear the data bits
LCDPORT|=((command & 0xf0)); //or in the new data
LCD_E = 1; //enable the LCD interface
NOP(); // delay of 1uS
NOP();
NOP();
LCD_E = 0; //disable it
void LCD_Data( unsigned char *string)
while (*string != '\0')
WriteChar(*string);
string++;
//Initialize I2C in master mode
void I2C_Initialized(void)
SSPSTAT=0x80; //Slew rate control is disabled for Standard Speed mode (100 kHz and 1 MHz)
SSPCON1=0x28; // I2C Master mode, clock = FOSC/(4 * (SSPADD + 1))
SSPCON2=0x00;
SSPADD = 49;
//100kHz clock @ 20MHz Fosc SSPADD = ( (Fosc/4) / BiteRate )-1
// SSPADD = ( 20MHz / 100KHz ) - 1 = 49
// Send an I2C START
// Return 0 if all ok, 1 if bus collision
__bit I2C_Start(void)
BCLIF = 0; //Clear 'Bus collision" flag
SEN = 1; //initiate a START cycle
while (SEN); //wait until it has been sent
return BCLIF; //return value of BCLIF flag
// Send an I2C STOP
void I2C_Stop(void)
PEN = 1; //initiate a STOP cycle
while (PEN); //wait until it has been sent
// Send an I2C REPEATED START
void I2C_Restart(void)
RSEN = 1; //initiate a REPEATED START cycle
while (RSEN); //wait until it has been sent
//Receive one byte. ackflag=0 to send ACK, or 1 to send NAK in reply
//Send one byte. Return 0 if ACK received, or 1 if NAK received
__bit I2C_Write(unsigned char dat)
SSPBUF = dat;
asm("nop"); // wait a little for R_W to be set
while (R_W); //wait until byte sent and ACK/NAK received
return ACKSTAT;
unsigned char I2C_Read(unsigned char ackflag)
RCEN = 1; // initiate a RECEIVE cycle
ACKDT =(__bit)ackflag; //specify if we should send ACK or NAK after receiving
while (RCEN); //wait until RECEIVE has completed
ACKEN = 1; //initiate an ACK cycle
while (ACKEN); //wait until it has completed
return SSPBUF;
//Send an array of data to an I2C device.
//Return 0 if all OK, 1 if bus error, 2 if slave address NAK, 3 if slave register NAK, 4 if slave data NAK
unsigned char Write_I2C_Device(unsigned char slave_address, unsigned char start_reg, unsigned char buflen, const unsigned char * bufptr)
if (I2C_Start() ) //send a start, and check if it succeeded
return 1; //abort if bus collision
//send the I2C slave address (force R/W bit low)
if (I2C_Write(slave_address & 0xfe))
I2C_Stop(); //if address was NAKed, terminate the cycle
return 2; //and return error code
//send the device register index
if (I2C_Write(start_reg))
I2C_Stop(); //if register was NAKed, terminate the cycle
return 3; //and return error code
//send the data. buflen might be zero!
for (; buflen>0; --buflen)
if (I2C_Write(*bufptr++))
return 4; //and return error code
I2C_Stop();
return 0; //no error
//Receive an array of data from an I2C device.
unsigned char Read_I2C_Device(unsigned char slave_address, unsigned char start_reg, unsigned char buflen, unsigned char * bufptr)
//do a dummy zero length write cycle to set the register address
unsigned char retval = Write_I2C_Device(slave_address, start_reg, 0, 0);
if (retval)
return retval; //abort if there was an error
//now start the READ cycle
//send the I2C slave address (force the R/W bit high)
if (I2C_Write(slave_address | 0x01))
//receive the data.
unsigned char ackflag = (buflen == 1); //1 if this is the last byte to receive => send NAK
*bufptr++ = I2C_Read(ackflag);
I2C_Stop();
const unsigned char ADS1115_data[] =
0x84, // MSB of the Config register to be written
0x83, // LSB of the Config register to be written
unsigned char rd_buf[2];
unsigned char A_buffer[20];
int ADC_Result;
float Result_V;
void main(void)
LCD_Initialized();
I2C_Initialized();
__delay_ms(10);
while(1)
__delay_ms(10);
asm("nop");
Result_V *= 2.048;
sprintf( (char *) A_buffer,"ADC value: %5f", Result_V );
LCD_Data(A_buffer);
I changed the size to 30 but still the data is not displayed.I do not see anything wrong, either. A common mistake is making the sprintf buffer too small but it looks OK at 20. Try making it bigger if you want but I don’t think it is a problem.
Does the formatted string appear in A_buffer after sprintf?I changed the size to 30 but still the data is not displayed.
yes look the pictureDoes the formatted string appear in A_buffer after sprintf?
Tried but doesn't workTry relocating WriteCommand(0x80) to just before lie 331 to give it a little time to execute.
Part of codeIn cases like this you just have to step it through and see where it is failing.
__delay_ms(10);
while(1)
__delay_ms(10);
asm("nop");
// WriteCommand(0x80);
Result_V *= 2.048;
asm("nop");
LCD_Data(A_buffer);
asm("nop");
yes it loop and change the string in Result_V when I adjust the potSo with WriteCommand (0x80) relocated to line 331 (and not present on line 341) it doesn't display?
Does it loop and change the string in Result_V as you adjust the pot? If so, it looks like a hardware or timing error on the LCD.
@JohnInTX Thank you for being with me in tough timeCan you break on line 342, the nop? The display should have the message there. Change the pot and click RUN and break on the nop again. The display should have a new value.
EDIT: Have you cycled the power to cold-start the LCD? Sometimes a 4 bit interface can get out of sync.
Consider turning on the cursor when you initialize the LCD. That way you can see if your initialization is OK and where the LCD thinks it should be on the line.
Change:
To:
WriteCommand(0x0F); //turn on display with flashing cursor
Consider writing 'RESET' on the display when you power up or reset the PIC. That way you know the LCD is ready to go.
You need a 2ms delay after the Clear Display command in the initialization.
// CONFIG1L
// CONFIG1H
// CONFIG2L
// CONFIG2H
// CONFIG3H
// CONFIG4L
// CONFIG5L
// CONFIG5H
// CONFIG6L
// CONFIG6H
// CONFIG7L
// CONFIG7H
#include <xc.h>
#include <stdio.h>
#include <conio.h>
// LATx registers
LATA = 0x00;
LATB = 0x00;
LATC = 0x00;
LATD = 0x00;
LATE = 0x00;
// TRISx registers
// Wait for 5 ms
__delay_ms(5);
//Initialized LCD
LCD_TRIS_RW=0;
LCD_RW=0;
__delay_ms(2);
NOP();
NOP();
WriteChar(*string);
string++;
SSPCON2=0x00;
SSPADD = 49;
// Send an I2C STOP
void I2C_Stop(void)
SSPBUF = dat;
return ACKSTAT;
return SSPBUF;
I2C_Stop();
if (retval)
//receive the data.
I2C_Stop();
unsigned char A_buffer[18];
int ADC_Result;
float Result_V;
void main(void)
LCD_Initialized();
I2C_Initialized();
__delay_ms(10);
while(1)
__delay_ms(10);
asm("nop");
WriteCommand(0x80);
Result_V *= 2.048;
asm("nop");
LCD_Data(A_buffer);
asm("nop");
When I click on debug button cursor doesn't blink so when I break on line "nop", Display doesn't show any messageCan you break on line 342, the nop? The display should have the message there. Change the pot and click RUN and break on the nop again. The display should have a new value.
previous version is working fine. I've tested below codeIf you have not made any other changes to the LCD code since the previous version that worked, I don’t know what is going on. A string is a string. If the LCD code is the same it should work with any string.
// CONFIG1L
// CONFIG1H
// CONFIG2L
// CONFIG2H
// CONFIG3H
// CONFIG4L
// CONFIG5L
// CONFIG5H
// CONFIG6L
// CONFIG6H
// CONFIG7L
// CONFIG7H
#include <xc.h>
#include <stdio.h>
#include <conio.h>
// LATx registers
LATA = 0x00;
LATB = 0x00;
LATC = 0x00;
LATD = 0x00;
LATE = 0x00;
// TRISx registers
// Wait for 5 ms
__delay_ms(5);
//Initialized LCD
LCD_TRIS_RW=0;
LCD_RW=0;
__delay_ms(2);
NOP();
NOP();
WriteChar(*string);
string++;
SSPCON2=0x00;
SSPADD = 49;
// Send an I2C STOP
void I2C_Stop(void)
SSPBUF = dat;
return ACKSTAT;
return SSPBUF;
I2C_Stop();
if (retval)
//receive the data.
I2C_Stop();
int ADC_Result;
float Result_V;
void main(void)
LCD_Initialized();
I2C_Initialized();
__delay_ms(10);
while(1)
__delay_ms(10);
asm("nop");
sprintf( (char *) A_buffer,"ADC value: %d", ADC_Result );
LCD_Data(A_buffer);
Result_V *= 2.048;
LCD_Data(A_buffer);
I sure don’t know…When I just add below part in code I wonder why I don't get adc value on display
done all as suggested but still facing same problemI sure don’t know…
EDIT: maybe I do know: At 18 bytes, A_buffer is not big enough for the message with the floating point and will overwrite whatever is next in RAM. Make A_buffer[40] for now.
That doesn't explain why just the 3 floating point operations in lines 6-8 would have an effect but get A_buffer bigger.
You might also mess around with where you declare Result_V, try it inside of main - compiler allocation problem?
Visit the Project Properties and see if there is any setting that affects floating point numbers - make sure they are set to 32 bits.
Grasping at straws here as I don't have a setup I can use to compile your code and test it right now.
Good luck!
Result_V = ADC_Result;
Result_V /= 32768;
Result_V *= 2;
sprintf( (char *) A_buffer,"ADC value: %d", Result_V );
LCD_Data(A_buffer);
Where is the declaration of the result variable? I initially thought you were creating a different instance of it with a different scope…done all as suggested but still facing same problem
I have done experiment to find out why data is not displaying
This is not what we really want but it confirm there is problem with float variable
when I declare int variable data display on screen but when I declare float, double, data doesn't display.
C:if(Result3 == 0) // if successful read.. { WriteCommand(0x80); //// Move the cursor to beginning of first line. ADC_Result = (rd_buf[0] << 8) + rd_buf[1]; Result_V = ADC_Result; Result_V /= 32768; Result_V *= 2; sprintf( (char *) A_buffer,"ADC value: %d", Result_V ); LCD_Data(A_buffer); }
float double Result_V;double Result_V;@JohnInTX sorry I'm coming back after almost a month. Me and my mother had some health issues so I couldn't continue thread. everything is fine now.I think you’ve been doing that but be sure you use %f in the format string when you are using Result_V or any other float.
// CONFIG7H
// CONFIG1L
// CONFIG1H
// CONFIG2L
// CONFIG2H
// CONFIG3H
// CONFIG4L
// CONFIG5L
// CONFIG5H
// CONFIG6L
// CONFIG6H
// CONFIG7L
#pragma config EBTR0 = OFF // Table Read Protect 00800-01FFF (Disabled)
#pragma config EBTR1 = OFF // Table Read Protect 02000-03FFF (Disabled)
#pragma config EBTR2 = OFF // Table Read Protect 04000-05FFF (Disabled)
#pragma config EBTR3 = OFF // Table Read Protect 06000-07FFF (Disabled)
// CONFIG7H
#pragma config EBTRB = OFF // Table Read Protect Boot (Enabled)
#include <xc.h>
#include <stdio.h>
#include <conio.h>
#define LCD_RS LATAbits.LATA2
#define LCD_TRIS_RS TRISAbits.TRISA2
#define LCD_RW LATAbits.LATA1
#define LCD_TRIS_RW TRISAbits.TRISA1
#define LCD_E LATAbits.LATA0
#define LCD_TRIS_E TRISAbits.TRISA0
// LATx registers
LATA = 0x00;
LATB = 0x00;
LATC = 0x00;
LATD = 0x00;
LATE = 0x00;
// TRISx registers
// Wait for 5 ms
__delay_ms(5);
//Initialized LCD
LCD_TRIS_RW=0;
LCD_RW=0;
__delay_ms(2);
void WriteChar(unsigned char Chr)
WriteNibble(Chr); //write the high nibble
WriteNibble( (unsigned char)(Chr<<4)); //then the low nibble
NOP();
NOP();
WriteChar(*string);
string++;
SSPCON2=0x00;
SSPADD = 49;
// Send an I2C STOP
void I2C_Stop(void)
SSPBUF = dat;
return ACKSTAT;
return SSPBUF;
I2C_Stop();
if (retval)
//receive the data.
I2C_Stop();
unsigned char A_buffer[40];
int ADC_Result;
float Result_V;
void main(void)
LCD_Initialized();
I2C_Initialized();
__delay_ms(10);
while(1)
__delay_ms(10);
WriteCommand(0x80); // this line update lcd line position
ADC_Result = (rd_buf[0] << 8) + rd_buf[1]; // this line update ADC value
Result_V *= 2.048 / 32768.0;
sprintf( (char *) A_buffer,"value: %5.3f", Result_V );
LCD_Data(A_buffer);
asm("nop");
