; Main.asm file generated by New Project wizard
; File:EADOG_asm code
; Created: dom lug 19 2020
; Processor: PIC18F452
; Compiler: MPASM (Proteus)
;REV.1_modified according web "F Text on a KS0108 Graphic LCD
;from Joe Colquitt
;REV.2_two rows with subroutine and macro
;PORTB.5 ---> C1SB of EADOG
;PORTB.6 ---> A0 of EADOG
;PORTB.0 ---> GLCD RST of EADOG
;PORTC.3 ---> CLK of EADOG SPI
;PORTC.5 ---> MOSI of EADOG SPI
; DEFINITIONS
#include p18f452.inc ; Include register definition file
CONFIG WDT=OFF
; VARIABLES
A0 equ 06h
SCK equ 03h
ch6 equ 1200h
strings equ 1000h
; RESET and INTERRUPT VECTORS
RST code 0x0
lin res 2
col res 2
temp0 res 2
cblock 0x0040
str_copy:12
endc
goto Start
; CODE SEGMENT
PGM code
Start
;******************** PROGRAM ORIGIN *****************************************************
;-------------------- PORTB AND SPI SETTING ----------------------------------------------
MOVLW 00h
MOVWF TRISB ;SET PORTB AS AN OUTPUT
MOVWF TRISC ;SET PORTC AS AN OUTPUT
MOVWF PORTC ;CLEAR PORTC
CLRF PCLATH ;ENSURE PCLATH BIT 3 IS CLEARED
bsf SSPSTAT,CKE
MOVLW 0x20
MOVWF SSPCON1
;-------------------- PROGRAM ROUTINE ----------------------------------------------------
goto MAIN
INIT
bsf PORTB,0
movlw 0x40
call PutCDM
movlw 0xA1
call PutCDM
movlw 0xC0
call PutCDM
movlw 0xA6
call PutCDM
movlw 0xA2
call PutCDM
movlw 0x2F
call PutCDM
movlw 0xF8
call PutCDM
movlw 0x00
call PutCDM
movlw 0x27
call PutCDM
movlw 0x81
call PutCDM
movlw 0x10
call PutCDM
movlw 0xAC
call PutCDM
movlw 0x00
call PutCDM
movlw 0xAF
call PutCDM
return
pgm_ram macro var ;macro to copy string from ROM to RAM
movlw upper(var) ;load TBLPTR with string address
movwf TBLPTRU
movlw high(var)
movwf TBLPTRH
movlw low(var)
movwf TBLPTRL
tblrd*+
call get_txt
endm
get_txt movf TABLAT,0 ;get characters until
btfsc WREG,7 ;W > 0x7f (ie FF terminator)
return
movwf POSTINC1 ;store in RAM
TBLRD*+
bra get_txt
golc movf lin,w
call PutCDM ;set row
swapf col,0
andlw 0x0F
iorlw 0x10
call PutCDM ; set coloumn high byte
movlw 0xF
andwf col,0
call PutCDM ; set coloumn low byte
return
wrstr movlw 0x00
movwf TBLPTRU
movlw high(ch6)
movwf TBLPTRH
movlw low(ch6)
movwf TBLPTRL
movf POSTINC1,0
btfsc STATUS,2
goto golc
addlw -0x20
mullw .6
movf PRODL,0
addwf TBLPTRL
movf PRODH,0
addwfc TBLPTRH
movlw .6
movwf temp0
movlw 0x00
call PutDat
p1_data TBLRD*+
movff TABLAT,WREG
call PutDat
decfsz temp0
bra p1_data
bra wrstr
return
MAIN
call INIT
movlw 0xB5
movwf lin
movlw .10
movwf col
call golc
lfsr FSR1,str_copy
pgm_ram pressu
clrf POSTINC1
lfsr FSR1,str_copy
call wrstr
movlw 0xB7
movwf lin
movlw .10
movwf col
call golc
lfsr FSR1,str_copy
pgm_ram tempera
clrf POSTINC1
lfsr FSR1,str_copy
call wrstr
FINISH
GOTO FINISH
;-------------------- TRANSMISSION SUBROUTINE --------------------------------------------
PutCDM
bcf PORTB,A0
bcf PORTB,5
MOVWF SSPBUF ;PLACE DATA IN BUFFER TO SEND
LOOP BTFSS SSPSTAT, BF ;CHECK IF TRANSMISSION IS COMPLETE
GOTO LOOP ;
bsf PORTB,5
RETURN ;RETURN FROM SUBROUTINE
PutDat
bsf PORTB,A0
bcf PORTB,5
LOOPD BTFSS SSPSTAT, BF ;CHECK IF TRANSMISSION IS COMPLETE
GOTO LOOPD ;
bsf PORTB,5
org strings
pressu db "Pressure",0xFF
tempera db "Temperature",0xFF
org 0x1200
db 0x0000,0x0000,0x0000,0x0000,0x0000,0x00 ;space
db 0x0000,0x0000,0x005f,0x0000,0x0000,0x00 ;!
db 0x0000,0x0007,0x0000,0x0007,0x0000,0x00 ;"
db 0x0014,0x007f,0x0014,0x007f,0x0014,0x00 ;#
db 0x0024,0x002a,0x007f,0x002a,0x0012,0x00 ;$
db 0x0023,0x0013,0x0008,0x0064,0x0062,0x00 ;%
db 0x0036,0x0049,0x0055,0x0022,0x0050,0x00 ;&
db 0x0000,0x0005,0x0003,0x0000,0x0000,0x00 ;'
db 0x0000,0x001c,0x0022,0x0041,0x0000,0x00 ;(
db 0x0000,0x0041,0x0022,0x001c,0x0000,0x00 ;)
db 0x0014,0x0008,0x003e,0x0008,0x0014,0x00 ;*
db 0x0008,0x0008,0x003e,0x0008,0x0008,0x00 ;+
db 0x0000,0x0050,0x0030,0x0000,0x0000,0x00 ;,
db 0x0008,0x0008,0x0008,0x0008,0x0008,0x00 ;-
db 0x0000,0x0060,0x0060,0x0000,0x0000,0x00 ;.
db 0x0020,0x0010,0x0008,0x0004,0x0002,0x00 ;/
;ASCII 30 - 3f, 48 - 63
db 0x003e,0x0051,0x0049,0x0045,0x003e,0x00 ;0
db 0x0000,0x0042,0x007f,0x0040,0x0000,0x00 ;1
db 0x0042,0x0061,0x0051,0x0049,0x0046,0x00 ;2
db 0x0021,0x0041,0x0045,0x004b,0x0031,0x00 ;3
db 0x0018,0x0014,0x0012,0x007f,0x0010,0x00 ;4
db 0x0027,0x0045,0x0045,0x0045,0x0039,0x00 ;5
db 0x003c,0x004a,0x0049,0x0049,0x0030,0x00 ;6
db 0x0001,0x0079,0x0005,0x0003,0x0001,0x00 ;7
db 0x0036,0x0049,0x0049,0x0049,0x0036,0x00 ;8
db 0x0006,0x0049,0x0049,0x0029,0x001e,0x00 ;9
db 0x0000,0x0036,0x0036,0x0000,0x0000,0x00 ;:
db 0x0000,0x0056,0x0036,0x0000,0x0000,0x00 ;;
db 0x0008,0x0014,0x0022,0x0041,0x0000,0x00 ;<
db 0x0014,0x0014,0x0014,0x0014,0x0014,0x00 ;=
db 0x0000,0x0041,0x0022,0x0014,0x0008,0x00 ;>
db 0x0002,0x0001,0x0051,0x0009,0x0006,0x00 ;?
;ASCII 40 - 4f, 64 - 79
db 0x0032,0x0049,0x0079,0x0041,0x003e,0x00 ;@
db 0x007e,0x0011,0x0011,0x0011,0x007e,0x00 ;A
db 0x007f,0x0049,0x0049,0x0049,0x0036,0x00 ;B
db 0x003e,0x0041,0x0041,0x0041,0x0022,0x00 ;C
db 0x007f,0x0041,0x0041,0x0022,0x001c,0x00 ;D
db 0x007f,0x0049,0x0049,0x0049,0x0041,0x00 ;E
db 0x007f,0x0009,0x0009,0x0009,0x0001,0x00 ;F
db 0x003e,0x0041,0x0049,0x0049,0x007a,0x00 ;G
db 0x007f,0x0008,0x0008,0x0008,0x007f,0x00 ;H
db 0x0000,0x0041,0x007f,0x0041,0x0000,0x00 ;I
db 0x0020,0x0041,0x0041,0x003f,0x0001,0x00 ;J
db 0x007f,0x0008,0x0014,0x0022,0x0041,0x00 ;K
db 0x007f,0x0040,0x0040,0x0040,0x0040,0x00 ;L
db 0x007f,0x0002,0x00c0,0x0002,0x007f,0x00 ;M
db 0x007f,0x0004,0x0008,0x0010,0x007f,0x00 ;N
db 0x007e,0x0041,0x0041,0x0041,0x007e,0x00 ;O
;ASCII 50 - 5f, 80 - 95
db 0x007f,0x0009,0x0009,0x0009,0x0006,0x00 ;P
db 0x003e,0x0041,0x0051,0x0021,0x005e,0x00 ;Q
db 0x007f,0x0009,0x0019,0x0029,0x0046,0x00 ;R
db 0x0026,0x0049,0x0049,0x0049,0x0032,0x00 ;S
db 0x0001,0x0001,0x007f,0x0001,0x0001,0x00 ;T
db 0x003f,0x0040,0x0040,0x0040,0x003f,0x00 ;U
db 0x001f,0x0020,0x0040,0x0020,0x001f,0x00 ;V
db 0x003f,0x0040,0x0030,0x0040,0x003f,0x00 ;W
db 0x0063,0x0014,0x0008,0x0014,0x0063,0x00 ;X
db 0x0007,0x0008,0x0070,0x0008,0x0007,0x00 ;Y
db 0x0061,0x0051,0x0049,0x0045,0x0043,0x00 ;Z
db 0x0000,0x007f,0x0041,0x0041,0x0000,0x00 ;[
db 0x0000,0x0000,0x0000,0x0000,0x0000,0x00 ;spare (Yen)
db 0x0000,0x0041,0x0041,0x007f,0x0000,0x00 ;]
db 0x0004,0x0002,0x0001,0x0002,0x0004,0x00 ;^
db 0x0001,0x0001,0x0001,0x0001,0x0001,0x00 ;_
;ASCII 60 - 6f, 96 - 111
db 0x0000,0x0001,0x0002,0x0004,0x0000,0x00 ;'
db 0x0020,0x0054,0x0054,0x0054,0x0078,0x00 ;a
db 0x007f,0x0048,0x0044,0x0044,0x0038,0x00 ;b
db 0x0038,0x0044,0x0044,0x0044,0x0020,0x00 ;c
db 0x0038,0x0044,0x0044,0x0048,0x007f,0x00 ;d
db 0x0038,0x0054,0x0054,0x0054,0x0018,0x00 ;e
db 0x0008,0x007e,0x0009,0x0001,0x0002,0x00 ;f
db 0x000c,0x0052,0x0052,0x0052,0x003e,0x00 ;g
db 0x007f,0x0008,0x0004,0x0004,0x0078,0x00 ;h
db 0x0000,0x0044,0x007d,0x0040,0x0000,0x00 ;i
db 0x0020,0x0040,0x0040,0x003d,0x0000,0x00 ;j
db 0x007f,0x0010,0x0028,0x0044,0x0000,0x00 ;k
db 0x0000,0x0041,0x007f,0x0040,0x0000,0x00 ;l
db 0x007c,0x0004,0x0018,0x0004,0x0078,0x00 ;m
db 0x007c,0x0008,0x0004,0x0004,0x0078,0x00 ;n
db 0x0038,0x0044,0x0044,0x0044,0x0038,0x00 ;o
;ASCII 70 - 7f, 112 - 127
db 0x007c,0x0014,0x0014,0x0014,0x0008,0x00 ;p
db 0x0008,0x0014,0x0014,0x0018,0x007c,0x00 ;q
db 0x007c,0x0008,0x0004,0x0004,0x0008,0x00 ;r
db 0x0048,0x0054,0x0054,0x0054,0x0020,0x00 ;s
db 0x0004,0x003f,0x0044,0x0040,0x0020,0x00 ;t
db 0x003c,0x0040,0x0040,0x0020,0x007c,0x00 ;u
db 0x001c,0x0020,0x0040,0x0020,0x001c,0x00 ;v
db 0x003c,0x0040,0x0030,0x0040,0x003c,0x00 ;w
db 0x0044,0x0028,0x0001,0x0028,0x0044,0x00 ;x
db 0x000c,0x0050,0x0050,0x0050,0x003c,0x00 ;y
db 0x0044,0x0064,0x0054,0x004c,0x0044,0x00 ;z
db 0x0000,0x0008,0x0036,0x0041,0x0000,0x00 ;{
db 0x0000,0x0000,0x007f,0x0000,0x0000,0x00 ;|
db 0x0000,0x0041,0x0036,0x0008,0x0000,0x00 ;}
db 0x0008,0x0008,0x002a,0x001c,0x0008,0x00 ;->
db 0x0008,0x001c,0x002a,0x0008,0x0008,0x00 ;<-
END
;******************** END OF PROGRAM *****************************************************
by Aaron Carman
by Duane Benson
by Aaron Carman
