Pic 16f877a
Hussienabdelraoof
Joined Apr 7, 2020
3
Dear all
I using my jdm circuit and pic 16f877a using xp windows without any problem when using windows 7 any thing not work i test more than programme of winpic not work
Note i using serial port Rs232
Please help
Thanks
jpanhalt
Joined Jan 18, 2008
11,087
I have been using Win7 to program numerous PIC16F's over the past several years with no problem. It is USB to my ICD3/PicKit3. No problem with Windows or PIC's. Get a decent programmer.
Ian Rogers
Joined Dec 12, 2012
1,136
WinPic may be a 16 bit application as its quite old... Try to run it as an XP application other than that you'll need to find an alternative..
AlbertHall
Joined Jun 4, 2014
12,640
Are you using a computer with a built-in serial port or a USB-Serial converter?
The USB-Serial converters don't usually handle the handshaking lines correctly and also introduce delays and both of these may prevent your programmer working correctly.
Hussienabdelraoof
Joined Apr 7, 2020
3
No i run on serial port built on pc
atferrari
Joined Jan 6, 2004
5,020
I know am not answering your OP but I suggest, if you can afford it, to buy a PICkit4 and to get a recent simple PC or laptop to work with MPLABX. I work in Assembly and everything goes reasonably well.
LesJones
Joined Jan 8, 2017
4,521
Are you running window 7 on the same that you had used with XP. The JDM programmer needs a good voltage on swing on the RS232 lines to generate the programming voltage. If it is a different PC the problem may be differences in the RS232 levels rather than the operating system.
Les.
