KL7AJ,
studiot,
I proposed an answer to your original question. Why don't you answer whether it is right or wrong so we can move on? And if wrong, why is it wrong?
Ratch
There are a lot of things you are not defining here. Is the size of the object in relation to the observer? Can the observer move around the object? Is the object close? If so, why can't the observer look at the object and see if it is rotating. And finally, you should post this in another new thread.While we're all rumiinating on the original post, here's another teaser in a similar vein. This is a pure thought experiment.
Let's say there's only one object in space. There are no other stars or other reference points. Can you tell if that object is spinning around its own axis? Does spin even have any meaning without outside references? How would you measure it? Or is spin only a RELATIVE parameter?
studiot,
Ratch
