I see a couple of potential problems. Your emitters are not being driven very hard. The mocrocontroller's outputs are not meant to push current. Using a Darlington array (one of the ULN series, like the ULN2803) will let you operate those IRLED's at closer to 50 ma so they are a lot brighter.
Second, your phototransistors turn on when lit and pull the level down. Using a larger resistor in series, like 27K, will let the signal drop closer to ground. At any rate, going to within .1 volt is well within the LOW logic level.
