Hello, can you give examples of photodiodes used as sensors in robotics? what are the applications?
K Thread Starter ketanco Joined Jul 29, 2014 23 May 6, 2017 #1 Hello, can you give examples of photodiodes used as sensors in robotics? what are the applications?
L LesJones Joined Jan 8, 2017 4,539 May 6, 2017 #3 If Google is broke you could try https://duckduckgo.com/ The application is to sense the intensity of visible, IR or UV light. (Depending on the specification of the device which can be found on the data sheet.) https://duckduckgo.com/ Les.
K Thread Starter ketanco Joined Jul 29, 2014 23 May 16, 2017 #4 Dodgydave said: Is Google broke?... Click to expand... no
mcgyvr Joined Oct 15, 2009 5,394 May 16, 2017 #5 To detect changes in light... Obstacle avoidance, line following, edge detection, near field communication,etc...
