I'm fairly certain, as I've also been having another issue with the table, in which say 1 out of every 10 times I power up the table, the lights are very dim and the 9v rail would only be showing about 1.5v. Strangely though, if I tapped AC127 lightly with an insulated screwdriver it would "wake up" and the table would work perfectly (at 9.7v though of course). I initially thought this was the AC127 failing. I checked, then checked again to see which pin of the transistor was soldered where, and it was definitely incorrect. This evening I flipped the transistor around and I have yet to see it exhibit this behaviour again. 9v rail is still sitting at 9.7v.Are you really sure it is the wrong way round?
Apart from the wrong zener voltage that circuit seems to be working correctly.
Unfortunately I don't own a multimeter with this function... but I've resoldered the transistor the correct way round and it seems to be working fine. I have already ordered a replacement transistor (reason for which I've mentioned above) so I will change it anyways.I don't see that the AC127 would have been damaged.
If your DMM has diode test range, do a diode test on the transistor out of circuit.
There are 6 measurements to be made: 3 measurements in both directions.
1) B - E
2) E - B
3) B - C
4) C - B
5) C - E
6) E - C
I put in a new and unused AC127 that I ordered previously. Turntable is working great, here's hoping it will last another 40 years.Good.
Did you replace/switch round the AC172?
| T | 2xAAA philips hue motion replaced by PSU | General Electronics Chat | 14 |
| Similar threads |
