PHILIPS 43PFT4002 /05
Cesco77
Joined May 23, 2022
307
Hi, could you please help me with this TV set, I have problem with backlight! I have install on this TV a new set of backlight (led strip) because the original one was blue tinted, but the new led doesn't power up! , so I thought that was the new led that wasn't working, and i tried to put back the old strips to see if they still working, but nether those old led strip that was working before now stop working, when you push the power button i can see them fleshing for fraction of second but nothing alse....By reading on this forum I get a second hand power supply because some people suggest that the power supply could be the cause, but it's still not working, it does the same of the old one! Before I change the blue tinted led the TV was working perfectly, what can it be wrong? Please if you someone could help because I'm stuck now, could be the main board?
twohats
Joined Oct 28, 2015
621
Have you damaged the connections? They can be very fragile.
Check with a magnifying glass.
Please post clear pictures of connections.
Good luck...........
Cesco77
Joined May 23, 2022
307
Thank you, I sort it out, was the new led which i get from AlyExpress not working! I connected this type of LED and now it works
T General Electronics Chat 14
