Hi all,
I am designing a circuit to measure voltage signals between 1-100MHz (multiple frequency content). The circuit is fed from a capacitive divider in order to safely convert from high to low voltage. Firstly could anyone recommend the best matching method for this frequency range at the output of the divider (parallel capacitor to ground) to 50Ω? The LV capacitor side is around 20nF. Initially, I have just attempted a 50Ω series resistor and some additional capacitors to get a flat 3dB magnitude response, however, there is a significant variation in S21 phase over the range and if I test the circuit with a time domain waveform there is a phase mismatch, as seen in the attached images. The simulation is done in ADS with port 1 set to the input to the capacitive divider, hence the poor S11 plot.
Are there any methods or commercial products that could shift the phase of the entire frequency range to a common reference point (e.g. 0 deg)? I don't know much about phase shifters but the ones I have seen shift the entire frequency range by a set amount, as opposed to an amount determined by frequency? Any advice is greatly appreciated.
thanks
thanks
