Phase Sequence Indicator
HighVoltage!
Joined Apr 28, 2014
182
I currently have a 208VAC (60Hz) Wye circuit. Is there such a Phase Sequencer Indicator that will trigger 3 separate relay outputs?
Ex #1: If phases a A-B REVERSED, relays A & B will pull in
Ex #2: If phases a A-C REVERSED, relays A & C will pull in
Each Leg to Neutral = 120VAC
Phase to Phase = 208VAC
MaxHeadRoom
Joined Jul 18, 2013
30,842
You mention a 3 phase star (wye) circuit, Then it would seem you are using 3 120v 1ph supplies, or do you have 3ph 208v loads also?
What configuration are you using?
Nothing is really clear in the OP!
A phase sequence detector is usually something else completely!
Max.
MaxHeadRoom
Joined Jul 18, 2013
30,842
By ground, I assume you mean Neutral?
I don't know of anything off the shelf, but there are phase rotation/sequence detectors.
How are the phases likely to be reversed, BTW?
Max.
HighVoltage!
Joined Apr 28, 2014
182
Max.
Max,
That is correct. The chances of happening are "somewhat" possible. However, this is more like an extra add-on sophisticated feature if that makes sense. Do they have anything that latches outputs?
MaxHeadRoom
Joined Jul 18, 2013
30,842
Normally these are used in elevators, remote/unattended Pumping stations, Also Fanuc CNC used to use one due to the servo drives being phase-rotation sensitive.
Normally they just shut down if a wrong rotation happens to occur, many have a sense contact that can be used as a alarm etc.
Max.
