Phase ,neutral and Earth detection
mohan.n2293
Joined Jan 23, 2017
60
Hi All,
We are doing small project on 3phase R,Y,B,phase and neutral indication circuit using lamp,
Please find the attachment of schematic.
when all the phases, neutral and Earth is present all 6leds will glow if not respective leds will glow.
The problem I'm facing here is when I interchange phase R and neutral lamp L1 should off because of diode reverse bias but here it is not happening,even for reverse supply lamp is glowing
mohan.n2293
Joined Jan 23, 2017
60
With the above circuit i'm measuring AC health condition ,this should indicates 3 phases ,Neutral and also Earth condition(present or not present)
Dodgydave
Joined Jun 22, 2012
11,395
Just use three neons across each Phase to Neutral or Earth with 220K resistors.
If you want to go across each Phase to Phase, then use 470K to 1M resistors.
