DickCappels
- Joined Aug 21, 2008
- 10,662
Thank you for correcting me about the values of those two resistors.
Figure the maximum power that you can dissipate with 240 VAC and 94 k Ohms. Subjectively, from your description of the damage there was a whole lot more power involved.
There would have been a couple milliamps going through the optical coupler. How can a couple milliamps at a couple of volts cause that kind of destruction?
My only conclusion is that either some wrong parts were used or the circuit was not faithfully followed.
You mentioned that you "...built that on a breadboard..." If it was one of those plastic plug-in breadboard might be that is part of the problem. Does it have a voltage rating? Maybe the connections on it are not what you expect -could be the result of a defect.
Maybe you would find that buzzing out the connections i nthat part of the circuit to be a profitable exercise. Then barring some kind of high voltage breakdown you will be able to separate problems with continuity from problems with components.
Not intending to argue, just trying to help you think about this..
