Phase and control [thyristor ]Help with understanding circuit diagram and component functions
Josephoffia
Joined Mar 1, 2019
I need to understand how the attached circuit diagram works and what each individual component does within the circuit. I would appreciate a detailed explanation "for dummies" as electrics is my kryptonite.
dendad
Joined Feb 20, 2016
4,642
This sounds like homework.
You will get a better response if you have a go at working it out and post your thoughts on how it works.
So, try to figure out the operation and write that up. Then folks may be more inclined to point you in the correct direction as needed when they see you have at least tried.
