pH sensor interface with LMC6482
DickCappels
Joined Aug 21, 2008
10,661
When I dip sensor in pH 4 , pH 7 solutions , I am getting same output voltage , there is no change. Am i missed anything in schematic.
What are the voltages that you see?
Are you remembering to subtract the offset?
Are you allowing some time for the probe to respond to the change in ph?
Can you post the datasheet for the probe or at least tell us the name if the manyfacturer and the part number?
