I have serveral (6) Surepet Surefeed Connect RFID feeders for my cats. They read RFID implants of the cat, and it only opens the bowls when the right cat is at the right feeder. It's this device: https://www.surepetcare.com/en-eu/pet-feeder/microchip-pet-feeder-connect
Now, this works, more or less but it's quite unstable. Because of that I'm thinking about removing the PCB and creating something custom instead. Using an arduino. That way I can completely customize it to my needs and connect it to a local application for datalogging.
I don't have experience with RFID readers so I'm thinking about buying this RFID reader board: https://www.ebay.com/itm/284550130560
It should return the cat's chip ID over a serial connection.
The only thing I'm not sure of:
Can I use the original RFID coil/antenna of the Surefeed Connect and just connect it to this PCB? Or does it neet to match the inductance of the included antenna/coil? Or can the PCB be adjusted to match that antenna/coil?
There's a teardown of the surepet feeders here: https://fccid.io/XO9-MPF001-001/Internal-Photos/Internal-Photos-2431846
It looks like there aren't many PCB's out there for reading RFID pet tags. So, I do hope this one will work.
Any help / suggestion is much appreciated!
