VCC and GND for all them are connected to one 12V battery right? What is R1 and L1 underneath Load?
val = peltier_level;
analogWrite(cold, val); //Write this new value out to the port You setting the power level here
digitalWrite (hot,LOW); //You set it low so power will flow make sure you keep one set low at
//any times or you'll have short.!!!!!
// add here to change from cold to hot
For the Arduino only the pins D1 and D2 are being utilized nothing in the analog? Also Should I change the code with the initilization variables to int hot = 1, int cold = 2? or int hot = 2, int cold = 1?Look this over and read it.
I didn't have a peltier it's just a load it could be a motor or in you case it going to be aCode:val = peltier_level; analogWrite(cold, val); //Write this new value out to the port You setting the power level here digitalWrite (hot,LOW); //You set it low so power will flow make sure you keep one set low at //any times or you'll have short.!!!!! // add here to change from cold to hot
peltier.
https://imgur.com/a/Zvq1D Sorry for being stupid but what do the squares indicate for the Arduino on pin 3 and 4? And I don't see pin 5 in the diagramYour setting the power with the pin 3 and setting the pin 5 low.
pin 3 is PWM
Wait so be80be's solution wouldn't work? How would I modify it?Hello,
The H-bridge can not work, as all N-fets are used.
To have the upper N-fet working, you will need a gate voltage higher as the powersupply voltage.
You could use a H-bridge driver between the arduino and mosfets to solve the problem.
what would the h-bridge driver look like instead of using a regular h-bridge since Bertus said that an H-bridge can not work as all N-fets are utilized.You can only use pwm pins 3 and 5 are good the drawing was wrong.
I picked 3 and 5 like this.View attachment 140353
Red of your peltier goes on 3 and ground on 5
Will it work at all though? I know it won't be that as efficient, but I'm just worry if it'll work :/Hello,
How does it reverse the current or control it of a peltier plate?Like this to get 12 volts
Oh thank you very much!!! Dude you're a lifesaver! I'm feel bad for asking so many questions. So I should use this circuit right?I just showed you 2 sim's it shows it working The Nfet's you have should work as the circuit I posted
just has voltage drop.
Serial.print("Power=");
Serial.print(power);
Serial.print(" PLevel=");
Serial.println(peltier_level);
digitalWrite(hot, LOW);
Okay, thank you again!Try it it should work Don't see it hurting nothing I'm getting tired I sim the wrong parts I post you a sim later.
Sim don't look goodHello,
:/// is there anything I can do to increase that?Sim don't look good
Looks like you get about 6.5 volts
| J | Repair PCB sitting on top of an aluminum plate | General Electronics Chat | 8 | |
| A | Help diagnosing this voltage regulator over heating and hotplate not heating? | Technical Repair | 7 |
