Peltier Plate Current Reversing and Controlling the Current with Arduino Uno
  • Thread starter Deleted member 496780
  • Start date
Joined Dec 31, 1969
I used an h-bridge to reverse the current of a peltier plate, which was the same as this video
In the video, he had to physically remove a wire and place it somewhere else to reverse the current of a peltier plate. I was wondering how would I do it without removing a wire?
Also how do I control the current flow with an Arduino? In the image I provided, I figured out how to control the current with just the peltier itself without reversing current or anything
Would the circuit for the DC motor controlled by a L293NE h-bridge work if I just replace the DC motor with the peltier plate?
Source: https://itp.nyu.edu/physcomp/labs/motors-and-transistors/dc-motor-control-using-an-h-bridge/
be80be
Joined Jul 5, 2008
2,396
L293NE probably not work it's only good for a 1 amp Continuous output current.
And that's on a pcb with heat sink made into it.
If you soldered it on a pref board you can't get a amp out of it.
Really need to know how big your peltier plate is.
That's not a good h-bridge for arduino you need to add some part's to insure that it don't power up and
have all 4 drivers on till your code is running.
wayneh
Joined Sep 9, 2010
18,183
Yes, but make sure the h-bridge is rated to the peltier current. Most small motors would draw much less current.
Joined Dec 31, 1969
Sorry I'm new to electronics, but is there a way to add a switch to switch from off, cold or hot, so I don't have to physically arrange the wires like the person did in the video
be80be
Joined Jul 5, 2008
2,396
Yes post the circuit there just swapping the drivers base.
It can be done with the arduino but you got have the logic right need to see link to circuit.
L293NE works fine if your around a 1/2 amp but to get up to the 1 amp mark you have to have heat sink witch need see a datasheet for your cooler.
Joined Dec 31, 1969
Ah sorry I don't have the schematic of the drawing since I just followed the guy in the video, but I'm not sure how I would incorporate a switch to manage off, cold or hot. I guess I'm scrapping the idea of controlling the temperature
Edit: Never mind the guy gave me his schematic! https://computerwizardlab.files.wordpress.com/2017/01/h-bridge-circuit.png?w=676
Joined Dec 31, 1969
This is the data sheet it shows 6.4 amps for the cooler http://peltiermodules.com/peltier.datasheet/TEC1-12706.pdf
That kills the L293NE can't use it
The IRLB8721PbF are not good for driving from a port pin of the arduino
Oh I won't be using an arduino anymore, but is there a way that I can add a switch instead so I don't have to physically adjust the wires for hot and cold? Here's a picture of the wiring, I am not sure where to put the switch, or what kind of switch I'd need. Thank you so much for your advice!
be80be
Joined Jul 5, 2008
2,396
I reread the data sheet if you hooked it up like this using your IRLB8721PbF for the ones that are on there
you could use the arduino.
be80be
Joined Jul 5, 2008
2,396
Yes they both work the dp-dt switch
or the h-bridge. I first though the IRLB8721PbF needed to much voltage to turn on but there 2.5 not 4.5
so the uno could switch them fine.
Just make sure your code doesn't set pin one and pin two high at the same time.
they need one low and one high at any giving time.
Joined Dec 31, 1969
Again thank you so much for helping me!!!!!! I was wondering would the arduino circuit you provided above look similar if I just replaced the mosfet?
I have this basic circuit drawn out similar to yours, I'm also going to be powering the peltier plate with 12v and the arduino with 9v
be80be
Joined Jul 5, 2008
2,396
The circuit I posted you have to use the IRLB8721PbF the one's in it are too small ,But all you do is use the IRLB8721PbF.
The Switch circuit will work too.
Joined Dec 31, 1969
Is Load the peltier plate? Sorry to ask again, what would the program look like roughly? Like this?
C:
int peltier = 3; //The N-Channel MOSFET is on digital pin 3
int power = 0; //Power level fro 0 to 99%
int peltier_level = map(power, 0, 99, 0, 255); //This is a value from 0 to 255 that actually controls the MOSFET
void setup(){
Serial.begin(9600);
//pinMode(peltier, OUTPUT);
void loop(){
char option;
if(Serial.available() > 0)
option = Serial.read();
if(option == 'a')
power += 5;
else if(option == 'z')
power -= 5;
if(power > 99) power = 99;
if(power < 0) power = 0;
Serial.print("Power=");
Serial.print(power);
Serial.print(" PLevel=");
Serial.println(peltier_level);
analogWrite(peltier, peltier_level); //Write this new value out to the port
be80be
Joined Jul 5, 2008
2,396
Something more like this
And try to use the code tag's its under the + button on the editor.
C:
int cold = 3;
int hot = 5;
int val = 0;
void setup() {
  Serial.begin(9600);
  pinMode (cold, OUTPUT);
  pinMode (hot, OUTPUT);
void loop() {
  char option;
  if (Serial.available() > 0)
    if (option == 'a')
      power += 5;
    else if (option == 'z')
      power -= 5;
    if (power > 99) power = 99;
    if (power < 0) power = 0;
  digitalWrite(hot, LOW);
  val = peltier_level;
  analogWrite(cold, val); //Write this new value out to the port
  digitalWrite (hot,LOW);
  // add here to change from cold to hot
Joined Dec 31, 1969
Code:
int cold = 3;
int hot = 5;
int val =0;
void setup() {
  Serial.begin(9600);
void loop(){
char option;
if(option == 'a')
power += 5;
power -= 5;
analogWrite(cold,val); //Write this new value out to the port
You're a guru! Thank you so much, but the code I posted was just to control the current of this https://imgur.com/a/OIOA2
I am not sure how to breadboard your schematic, and reverse the current. Also in the code what component is connected to pin 5 of the arduino for the hot side?
