I'm new to this forum and need a little help with a simple alarm circuit. I have a set of PE beams (Aleph XA100) across my driveway
when the beam is tripped it sounds a sonalert and lights a led. The sonalert is supposed to latch on until a momentary switch is opened and then stay off until the PE beams are cleared, then reset and be ready to go off again, and the led is supposed to follow the status of the PE beams no matter what state the sonalert is in. I also have a manual switch to silence the sonalert if we leave the house, but the Led is supposed to still work on and off with status of the PE beams.
This circuit is almost 30 years old and when I opened the box it was a total birds nest and I had to cut the wires. Recently I've had to replace the wires going outside and now it's not working right. it trips ok and latches on, but the sonalert won't stay off when I hit the momentary reset if the PE beams are still tripped.
here's a little sketch of what I have, I tried to do it with a latching relay but that didn't work either. the max current I can put through the PE beam contacts is 300ma and I want to try to stay a little below that.
Thanks for any help you can provide.
John Kruse
John Kruse
