Pcm
mleniger
Joined Jan 7, 2026
9
1997
A replacement part for that transistor??What was it in??
I think that is a "Harris" logo.
1997 F250 PCM yes I know I can spend 300 to 1000 for a new PCM but I accepted the challenge to fix this one because it's just like a epoxy board on any other electronic
mleniger
Joined Jan 7, 2026
9
What does the rest of the board look like?
It's was all repairable it's just this one transistor that needs to be replaced I was able to threw with a magnifying glass and replace capacitors and kept everything below 160c to 150c that's about 300 to 320 Fahrenheit
mleniger
Joined Jan 7, 2026
9
I just saw transistors myself. I thought it would be a good place to start. Sorry I cant be of more help.
No your good I'm just stressing and the wife told me that I have until January 21st or I'll have to buy a replacement pcm
32,824
Is it even a transistor? Could be one of many things. The number is probably an OEM house number, which will make finding information about it very difficult.
schmitt trigger
Joined Jul 12, 2010
2,088
I am with WB on this one. Harris semiconductor was never a discrete transistor powerhouse. For all I know, it could be a voltage regulator.
But like an isolated word from a language you don’t know, context IS EVERYTHING.
In this instance, context would be the circuitry that this device is connected to.
EDIT; the corrosion is indeed severe. Did you replace the component just by its looks or how EXACTLY did you determine it was faulty if you don’t know what it is?
mleniger
Joined Jan 7, 2026
9
Did get it down to a 100v 2amp regulator
mleniger
Joined Jan 7, 2026
9
Why would a 12 volt system use or need a 100 volt regulator?
Possibly a 5 volt regulator.
Well Iam going to wing it at this point with even a PCM repair person even saying that they have no answer they don't replace them they scrap them that are like this
schmitt trigger
Joined Jul 12, 2010
2,088
Automotive companies make every effort possible to prevent repairs to their electronic modules.
Having worked for a Tier-1 electronics module supplier for automotive electronics, I can tell you that automakers don’t even allow the original module manufacturers to repair them, even though we had all the required information, equipment and components.
When we received a defective module, we would only make an in-depth analysis, provide root cause and corrective actions, and then scrap the unit. In certain modules, scrap meant crushing the unit.
32,824
Even more to the point, if that part is that severely corroded, it's hard to imagine that there isn't corrosion damage elsewhere that is just as bad.
