1997 F250 PCM yes I know I can spend 300 to 1000 for a new PCM but I accepted the challenge to fix this one because it's just like a epoxy board on any other electronicA replacement part for that transistor??What was it in??
I think that is a "Harris" logo.
It's was all repairable it's just this one transistor that needs to be replaced I was able to threw with a magnifying glass and replace capacitors and kept everything below 160c to 150c that's about 300 to 320 FahrenheitWhat does the rest of the board look like?
What did you find because I found the ones I don't need lolGoogle 1002SEDA
No your good I'm just stressing and the wife told me that I have until January 21st or I'll have to buy a replacement pcmI just saw transistors myself. I thought it would be a good place to start. Sorry I cant be of more help.
Did get it down to a 100v 2amp regulatorI am with WB on this one. Harris semiconductor was never a discrete transistor powerhouse. For all I know, it could be a voltage regulator.
But like an isolated word from a language you don’t know, context IS EVERYTHING.
In this instance, context would be the circuitry that this device is connected to.
EDIT; the corrosion is indeed severe. Did you replace the component just by its looks or how EXACTLY did you determine it was faulty if you don’t know what it is?
Well Iam going to wing it at this point with even a PCM repair person even saying that they have no answer they don't replace them they scrap them that are like thisWhy would a 12 volt system use or need a 100 volt regulator?
Possibly a 5 volt regulator.
Said they don't go that deep into them they keep it simple if it's not then they just strip the boardSeems strange a PCM "repair" person would not know what that part is.
Even more to the point, if that part is that severely corroded, it's hard to imagine that there isn't corrosion damage elsewhere that is just as bad.I am with WB on this one. Harris semiconductor was never a discrete transistor powerhouse. For all I know, it could be a voltage regulator.
