PCB Track Sizes
JDR04
Joined May 5, 2011
367
Can somebody please tell me what track sizes I should use for my pcb design.
My circuit is a micocontroller circuit that detects light and runs on 5V dc. So it uses a few resistors,phototransistor and a optocoupler. Hope this helps but if its too general let me know.
Many Thanks.........JDR04
34,820
There are many factors that will determine track widths:
1. Are you etching the board yourself or will a PCB shop do it for you?
2. Thru-hole components or SMD
3. Fine lead spacing ICs or 0.1" DIP ICs
4. Any traces in between IC pins
5. Current carrying requirements
6. Signal frequency and noise considerations
Some PCB shops can do 0.005" (0.13mm) - 0.007" (0.18mm). You do not want to get that narrow.
Your minimum may be 0.010" (0.25mm) or 0.015" (0.38mm)
If you are using 0.1" DIP ICs with no traces between pins 0.025" (0.635mm) to 0.035" (0.89mm) is good to work with DIY etching.
For power traces, I like to go up to 0.050" (1.27mm) and beyond depending on the current requirement.
Finally for GND you want to flood as much of the area as possible to provide a ground plane and to make etching easier on your chemicals.
JDR04
Joined May 5, 2011
367
Thanks to eveyone. Information has helped me greatly.
