PCB Layout Rules for Raspberry Pi Project
phillipsoasis
Joined Aug 22, 2022
170
I have designed a "daughter board" for a Pi Zero W and I am starting to layout the PCB. I was wondering what your recommendations would be for ground, 5V and 3.3V connections. I plan to put a 40 pin header on my board and plugging in the Pi Zero.
Do you recommend connecting all the 3.3V pins on the header to the 3.3V bus, all the 5V pins to the 5V bus, and all the ground pins to ground? Or, just one of each to each power connection?
Thanks!
35,093
Thanks!
I would connect them all as you have described.
bidrohini
Joined Jul 29, 2022
190
